7.3 powerstroke cam sensor issues? - Ford Truck Enthusiasts Forums
Old 02-04-2011, 01:14 PM
seanj5202 seanj5202 is offline
seanj5202 is starting off with a positive reputation.
i have a 99 f250 7.3 powerstroke. the cam sensor was acting up. that what the scan tool said. i replaced the cam position sensor yesterday, and the truck is still acting up. the motor hitches and will shut off randomly. it tripped the check engine light, and the code is the "cam position sensor" once the truck is warmed up and shut down for like 10 minutes the sensor will not act up anymore. if i just start the truck and run it, even once it is up to tempature it will act up. but if i shut the truck down for about 10 minutes, it goes away. is there something else that could be causing this? thank you
Old 02-04-2011, 01:28 PM
Trucky2's Avatar
Trucky2 Trucky2 is offline
Trucky2 is gaining momentum as a positive member of FTE.Trucky2 is gaining momentum as a positive member of FTE.
Did you get an OEM CPS or maybe something from an auto parts store? There's lots of discussions regarding this in the 7.3 forum. Some say the aftermarket CPS units have not worked right for them and swear by one of the OEM versions.
Old 02-04-2011, 02:05 PM
i got this sensor from napa. ill check out the 7.3 forums, thanks
Old 02-04-2011, 02:12 PM
SC74 SC74 is offline
SC74 is starting off with a positive reputation.
Did you disconnect your battery when you installed it. I've heard that you need to disconnect the battery for aprox 30 min to reset the computer so it re-learns the new sensor.
Old 02-04-2011, 02:31 PM
i didnt disconnect the batteries, but i read somewhere to pull the #9 fuse under the hood? can i still disconnect the batteries now, will the computer recognize the new sensor?
Old 02-04-2011, 03:12 PM
also should i remove the sensor and coat it in vasoline? i only coated it in oil before inserting it into the motor. thanks
Old 02-04-2011, 06:11 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
You don't need to disconnect the batteries. If the CPS is good then the PCM will see the tach signal and everything will be fine.
If you want to put vaseline or di-electric grease on something, it goes on the rubber gasket at the plug connector. This helps provide a better seal that will keep moisture out of the electrical connection.
And as Ken originally said. Too many problems with the aftermarket CPS from places like NAPA etc. Stop by Ford and you should be able to pick one up for around $25.
Old 02-04-2011, 07:44 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Powerstroke Diesel forum.
Old 02-05-2011, 12:41 AM
aklim's Avatar
aklim aklim is offline
aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.
Quote:
That could be an issue. From what I heard, either get them from International or Ford.
Old 02-05-2011, 01:30 AM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
zx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant future
Stay away from the aftermarkets. Seen too many of them have issues. Make sure the code reader you are using is PSD compatible. If not, it may not even be reading the codes right. Your problem does sound like a CPS, but there could be other things that cause it.
Old 02-05-2011, 01:52 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
Here is a good link for you that will help you know the difference between different CPS sensors.
Black CPS proves to lower PERDELS again
Old 02-05-2011, 06:59 PM
where can i pick up a "black" cps? from a ford or international dealer?
Old 02-05-2011, 08:01 PM
szotty szotty is offline
szotty is starting off with a positive reputation.
dont think you can get black one from anyone other than clay at riffraft or bob at diesel orings
Old 02-05-2011, 08:09 PM
zx250's Avatar
Clay has them and his link is in my signature.
Old 02-05-2011, 08:42 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Flip a coin.
Heads Dieselorings - Tails Riffraff
Dieselorings Black CPS
Riffraff Black CPS
1995 7.3 Powerstroke won't start Powerstroke1995 1994.5 - 1997 7.3L Power Stroke Diesel 37 03-17-2017 02:44 PM
1995 7.3 powerstroke 95Fordf350 1994.5 - 1997 7.3L Power Stroke Diesel 6 02-19-2017 11:21 AM
Random loss of power?? 95seventhree 1994.5 - 1997 7.3L Power Stroke Diesel 5 01-25-2016 08:38 PM
engine stalls after warming up for 10-20 minutes gary.aderhold 1999 - 2003 7.3L Power Stroke Diesel 50 12-11-2015 05:48 PM
Another head scratcher......... BoydII 1999 to 2016 Super Duty 6 11-28-2015 08:25 PM
Tags
01, 73, 97, 99, autozone, cam, camshaft, cps, f350, forum, napa, position, power, powerstroke, sensor, stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
