OD blinking light fix.
Ok so like a lucky few of you i have the blinking OD light and think i know what it is but hoping to get a couple other ideas to fix it. I got the truck coded a while back and it had a tc fault code, dont remember exactly what it was. And when i get into on-off traffic it sets off the od light and starts shifting hard. So im trying to deny the expensive fact that i might need a new tc or tranny. So is it possible that i need just a new tc or the entire tranny built, it shifts perfect when the od isnt blinking. i was looking for some links or help to fix this problem. What else could set the od off and make it shift hard? I know i should probably take it to a tranny shop to have it looked over, just thought i would come here first like i always do.
Look on top of your rear diff case. There is a sensor. It is the vehicle speed sensor. Take out the one bolt holding it in, pull out carefully as I've seen one broken off(wouldn't want to drop it into the diff if so), and inspect/clean. Sometimes that is all that causes the hard shifts. In my case I had the OD light blinking and threw a TC fault code and needed a new TC or tranny. I didn't go to the work of rebuilding it all or diagosing tc vs trans, instead swapped to a zf so no help from me there. Good luck and if that doesn't work then you may have a ticking bomb so don't push it.
Blake, I have had my OD light come on many times and have been trying to figure it out for quite a while, I have taken truck to shop that my buddy owns but he says that everything looks good inside, fluid is red , no smell, pessures are good and don't think it needs to be rebuilt. We did change the VSS a few years ago and some kind of electrical pack in the tranny but I still have the problem once in a while.
RB - 96 350, PSD, auto, 4X4
Yeah, anytime that OD light is blinking, its on its way out the door.. Other Ford models will do the same thing before going toast. The fact that you had a friend install the treatment already last year, I think you milked her for all you could!
Hey, you were looking to upgrade anyways, right?
