tires & 6.2 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
tires & 6.2
Old 02-03-2011, 07:30 PM
vtragweed vtragweed is offline
vtragweed is starting off with a positive reputation.
tires & 6.2
with the 6.2 and the 4:30 gears will a 33' tires knock it down to a 4:10 and result in better mpg?
Old 02-04-2011, 09:21 AM
Radioactive 4x4's Avatar
Radioactive 4x4 Radioactive 4x4 is offline
Radioactive 4x4 is starting off with a positive reputation.
A 275/70/18 tire is a 33" tall tire. Metric To Inches Tire Size Conversion I think maybe going to a 35" might do the trick. That is what I am planning.
Old 02-04-2011, 09:48 AM
Scrming's Avatar
Scrming Scrming is offline
Scrming is starting off with a positive reputation.
Quote:
How much heavier will the taller tires be? If they are heavier then it would most likely offset any kind of fuel savings. The things is extra weight in the tires is not simply dead weight, it's rotating weight which is something like double... so if you r new tires weight 5 pounds more that's really like 10 pounds of dead weight... times that by four... Of course I realize there that is still very small compared to the overall weight of the truck.... But then again how much difference in MPG is there between the 4.30s and 4.10s?
Also probably going to want to have the computer changed to reflect the taller tires to correct the speedo...
Tuning Fmc4lfe 2017 Super Duty 7 02-10-2017 08:18 PM
6.2L MPG carlhwv 1999 to 2016 Super Duty 28 10-15-2016 11:00 AM
15' 6.2 Tuner stufarmer 1999 to 2016 Super Duty 16 10-01-2016 10:22 PM
35s on a 6.2 gas gustrider4 1999 to 2016 Super Duty 16 01-18-2016 11:12 AM
5.4 to 6.2 jowens1126 6.2L V8 6 02-26-2015 12:00 PM
Tags
430, 62, gears, kind, mpg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
