04 F150 5.4 fuel gauge not working???
Old 03-16-2012, 08:28 PM
Duffy289hp's Avatar
Duffy289hp
Duffy289hp is offline
Just bought a 04 f150 crewcab 4x4 and the fuel gauge doesnt work. Anyone have any suggestions??
Old 03-16-2012, 08:31 PM
Duffy289hp's Avatar
Duffy289hp
also on of my back windows doesnt not work, i would really apprieciate any input i can get!
Old 03-16-2012, 09:12 PM
1969furd's Avatar
1969furd
1969furd is offline
back windows is probably a switch or regultor or motor
Old 03-16-2012, 10:56 PM
Greg B's Avatar
Greg B
Greg B is offline
Fuel gauge could be fuel pump, sending unit, or gauge itself. The Ford shop manual will help you diagnose without replacing parts unnecessarily. Just follow the steps.
Old 03-17-2012, 10:23 AM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
Disconnect connector C434 by gas tank, resistance to sender should be between 30 and 150 ohms. The higher reading will be for a full tank. 0 ohms would be shorted and infinity would be open sender. Check papa tigers pictures for a picture of the circuit. For rear windows, make sure back windows aren't shut off. Also, Check where the wire loom bend inside the rubber cover between the door and the door post. Sometimes the wire breaks at the bend area inside the cover. Yellow/blk and red/blk wires, power rear windows. Also check one touch relay for open condition.
Old 03-17-2012, 11:00 AM
mtpockets20's Avatar
mtpockets20
mtpockets20 is offline
for the back window did you try rolling it down with just the drivers side switch or did you try with the actual window switch, if niether works you will need to buy a new regulator
Old 03-17-2012, 07:26 PM
danorules's Avatar
danorules
danorules is offline
Try running fuel system cleaner repetitively through a few tanks.I read a while back that the float gets gummed up and the fuel system cleaner fixes that. Brings the gauge back to life
Old 03-18-2012, 08:57 PM
Mr.Rogue's Avatar
Mr.Rogue
Mr.Rogue is offline
fuel gauge issue
if the 2004 is the same as the 2006, you may want to check the 10 wiring harness behind the plastic cover, underneath the drivers side door on the frame rail. that waterproof connector gets all corroded and alot of crap runs through that harness.
mine actually melted, and cost my 500 bucks to pinpoint the problem and repair.
Good luck
Old 02-17-2013, 03:18 PM
nflder's Avatar
nflder
nflder is offline
I 2nd Mr.Rogue (mine is 2007).
Truck was sitting for a week last year. Started it up and fuel gauge went past E. After a day or so it started working again....until last week.
So last week the gauge starts doing the same thing as last year. I let it go figuring maybe I'll get lucky again this time around. No go. The battery died last night so this time I went hunting....
After reading posts on this forum I went straight to the connector on the frame rail under the drivers side door. When I unplugged it the problem was pretty apparent. One of the wires pins were corroded whereby it was broken right off. Then I could hear something....sizzle...sizzle....it was the connector melting right in my hand (ignition was OFF at this point). Spliced the offending circuit and VOILA! gas gauges works!
Thanks to all who posts in forums such as this. Not the 1st time thsi has saved me a trip to the garage/dealer!
Cheers!
Mpetty321
1999 to 2016 Super Duty
01-13-2017 05:44 PM
Jeffrey Breaux
08-22-2016 01:57 PM
Duffy289hp
2004 - 2008 F150
05-28-2012 11:59 AM
Quick Reply: 04 F150 5.4 fuel gauge not working???
