92 F-150, duel tank fuel system - Ford Truck Enthusiasts Forums
Old 02-03-2011, 07:29 PM
Firefighter0513 Firefighter0513 is offline
Firefighter0513 is starting off with a positive reputation.
I have a 92 f-150 extended cab 4x4 with duel tanks, the truck quit running on the front tank so i switched to the rear tank. The truck will run on the rear tank, but it is pumping the gas from the rear tank to the front tank. Can anyone tell me if this is a pump problem or a valve problem? Any help i can get would be great. Thanks
Old 02-03-2011, 08:45 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
It is a valve problem in the front tank.
Old 02-04-2011, 05:45 PM
SilverSport SilverSport is offline
SilverSport is starting off with a positive reputation.
It will require replacement of front tank pump assy, the valves are built in. After you fix this you may have the poblem I have I described here http://www.ford-trucks.com/forums/10...ed-issues.html
Old 02-05-2011, 02:05 PM
Thanks for the help. I have talked to 2 dealerships that said there was a frame mounted switching unit but i could not find it, had a buddy that used to work for a ford dealer look at it and could not find it. I'm going to replace the front pump. Thanks again for the info.
Old 02-05-2011, 02:12 PM
subford's Avatar
A 1992 F150 does not have a frame mounted switching unit.
Dealerships do not understand F-series trucks fuel systems from 1985-1995.
The last F-series gas truck to have a frame mounted switching unit was the 1989.
Old 02-05-2011, 02:25 PM
They had me puzzled i was looking all over the place under that truck and could not find one. The said it should be on the frame and thought i didn't know what i was talking about. So the valve is in the pump unit itself then?
Old 02-05-2011, 03:06 PM
subford's Avatar
Quote:
Yes it is:
duel fuel tank wiring f250 1985 f150rd 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 12-18-2011 04:46 PM
1989 Ford F250 Duel Tank Problem JasonDaniel 1987 - 1996 F150 & Larger F-Series Trucks 5 10-04-2011 05:14 PM
Duel gas tank problems 1995 F-250 wvmedic 1987 - 1996 F150 & Larger F-Series Trucks 3 07-05-2010 07:10 PM
Duel fuel tank question ltatkinson 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-09-2009 11:35 AM
f150 duel fuel tanks craigebear 1987 - 1996 F150 & Larger F-Series Trucks 6 05-16-2004 11:18 PM
Tags
150, 1990, 1996, 460, 92, duel, f150, ford, fuel, images, size, system, systems, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
