A new tool to Grease Front 4x4 Hub Bearings
After seeing several Threads about greasing those "unserviceable" Front Hub Bearings I thought it was time to service the Front Hubs of my 2003 Excursion 4x4. (No need to remove Hub from Vehicle)
I came up with a simple "tool" that I made from my boxes of misc stuff - saved to use sometime. Picture shows the details (below).
1. Remove Wheel/Tire (Jack up and Safely support)
2. Remove Brake Caliper and Bracket and Rotor. (Mark Rotor to stud position)
3. Clean area around ABS sensor. (Bend cover up for access)(Area sprayed with white paint for picture)
4. Remove ABS sensor and lay aside. (No need to remove totally)
5. Insert Greasing Tool and fill cavity. (About 35 pumps of Grease Gun)
(I used Mobil 1 Grease. One tube will do both sides)
6. Wipe off excess grease. (Bend ABS Cover back in place)
7. Assemble in reverse order.
That's a pretty good setup.
Here's a few good threads on the subject.
https://www.ford-trucks.com/forums/8...pics-here.html
https://www.ford-trucks.com/forums/8...bearingss.html
I'd like to get one of the custom fittings made one of these days.
I want to give credit to the members that discovered this feature several years ago.
on
WOW!
I am the one that wrote the post; "greasing your main wheel hub bearings" and you went me one better! That is a fantastic idea and for those who are skeptical; if you like shot bearings, don't do it, otherwise do it. I filled mine all the way up and they still don't leak or anything. Reps given!
Anybody know if the 2005 and later models use the same setup? (I'm 1500 miles away from mine...)
Noticed after reading through all the links that the 2005 and later (i.e. coil-spring models) aren't represented....
Edit: Note that the HUBS changed in 2005, but this tool is for the WHEEL BEARINGS, not the hubs.
-blaine
-blaine
