Eliminate Accessory Delay - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-03-2011, 04:00 PM
RogerG RogerG is offline
RogerG is starting off with a positive reputation.
Hello Everyone
My '02 F250 SD is equipped with an accessory delay. When I turn the ignition switch off, the interior light comes on, the radio keeps playing, etc.. Is there anyway to eliminate this feature? When I turn the key off, I want everything off and I sure do not want the dome and cargo light to come on.
Thank you,
Grits
Old 02-03-2011, 05:03 PM
brd7666's Avatar
brd7666 brd7666 is offline
brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.
I would pull out the accessory Delay Relay, and see what happens. If you look in your owners manual, you will see where it is located.
Old 02-03-2011, 05:12 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
I don't think there is any way to change that behavior, and if you remove the accessory relay then none of those accessories will work at all.
The radio should go off as soon as you open a door. And the dome light goes off after a short period too. It's not like these things are going to run your battery down.
I really don't understand why you want to change it, but that's your business. As far as I know there is no way to program it any differently. Maybe someone else has an idea.
Old 02-04-2011, 05:58 AM
Why
I am a farmer. On occasion, I shoot varmints from my truck. I want it quite and dark when I shut it down.
Also, I do not think it is a good idea from a security standpoint.
Grits
Old 02-05-2011, 01:05 AM
JockD's Avatar
JockD JockD is offline
JockD has a very good reputation on FTE.JockD has a very good reputation on FTE.JockD has a very good reputation on FTE.JockD has a very good reputation on FTE.
But the cops love it because they can see what the bad guys are doing after a traffic stop.
Even on my bare-bones XL the dome light stays on for a while after I open the door with the key on. I hate it, too.
Old 02-05-2011, 03:30 AM
helomech's Avatar
helomech helomech is offline
helomech is starting off with a positive reputation.
What about turning off the stereo...? as for the dome light, can't you just turn it off? ie, roll the dash dimmer all the way off until it clicks and turning off the dome?
Old 02-05-2011, 04:54 AM
That might work but the light has already come on. Thanks, Roger
Old 02-05-2011, 06:53 AM
helomech's Avatar
Right, but if you turn the dimmer all the way down and click the dome light off BEFORE it comes on, then it wouldn't be an issue and you can sneak up on them thar critters..
Old 02-05-2011, 10:27 AM
I will try it
As soon as my instrument cluster gets here I will try it. The dome light does not work at all if the battery saver relay goes bad. It is a non-serviceable part in the instrument cluster.
Roger
Old 02-05-2011, 10:38 AM
Rickx Rickx is offline
Rickx is gaining momentum as a positive member of FTE.
Here's a thread on how to bypass and control your running board and interior lights. I went through the instrument panel to do this. Most are going through the driver's kick panel. Once you have this installed your map and cargo light switches will still function normally. This is on Excursions, but should be the same for Superdutys. Most of us did it because of malfunctioning door jam switches(door ajar).
http://www.ford-trucks.com/forums/93...itch-oops.html
Old 02-05-2011, 07:01 PM
fuelman fuelman is offline
fuelman is gaining momentum as a positive member of FTE.
It's actually the passenger side kick panel.
Old 02-05-2011, 08:34 PM
Gordon-0 Gordon-0 is offline
Gordon-0 is starting off with a positive reputation.
wouldnt it be easier to replace the time delay relay with a regular non time delay relay?
the other option is to put another switch in to mimic the switch in the door.
run a switch in series with one of the switches in the door jamb. it will prevent the truck from seeing the open door, so it will think the door is still closed when you have the swich "on". you are on your own for the radio
Old 02-05-2011, 08:45 PM
Anomic Anomic is offline
Anomic is starting off with a positive reputation.
How about my 2010 turns on the parking and dome lights on when i turn key off (stays on about 60secs). I would love to never hear "you left your lights on" everytime i get out of my truck. Not to mention the above mentioned security reasons
Old 02-05-2011, 09:51 PM
Quote:
I contributed to that post, but I didn't read it all. So... good call.
Old 02-05-2011, 09:55 PM
Quote:
Roger
It's going to be really simple to install a switch if you're going to be dealing with your cluster anyway. Just know - you want the Black wire with blue stripe. There's only one. Just install a switch in that circuit and you're good to go.
Accessory delay relay Dan V 1999 - 2003 7.3L Power Stroke Diesel 17 01-04-2017 10:42 AM
How do i ad a delay to a 12v accessory? dn29626 1999 - 2003 7.3L Power Stroke Diesel 1 08-26-2012 03:31 PM
2005 headlight delay relay?? Help I M Stuck 1999 to 2016 Super Duty 2 07-24-2009 04:03 PM
Delayed Accessory Power....Turn Off? Matt M, PA Excursion - King of SUVs 9 02-14-2005 10:00 AM
Accessory Delay Relay MrGrizzlyAdams 1999 to 2016 Super Duty 4 11-04-2003 10:21 AM
Tags
150, 2010, accessory, aviator, delay, delayed, disable, f150, f350, ford, relay, staing, superduty, turn, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
