1999 Lincoln Navigator Theft light, Stalling - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-03-2011, 11:09 AM
preacha65 preacha65 is offline
preacha65 is starting off with a positive reputation.
Hello I have 99 Linc. Nav. AWD, It has an issue with the electrical system. The theft light flashes faintly and rapidly when under a slight strain like small to moderate inclines. It has completely stalled on me to times.Another case it lost all power but, the engine kept running at a low rpm and you could not rev it up with the accel pedal and the most recent issue was it jumped out of gear while going up a small incline. Every time I have had an issue with it I pulled off to the side of the road and turned the ign switch to off and turned it back on and it will run fine. I have read a lot of threads but, none seem to match mine exactly. Any help would be appreciated. Thanks
Old 02-03-2011, 11:24 AM
97ExpGuy 97ExpGuy is offline
97ExpGuy is gaining momentum as a positive member of FTE.
Are you using the factory key with the chip in it?
I know that some aftermarket devices (fits inside the column) allow you to operate the vehicle with via a regular key because it overrides the factory anti-theft device. Otherwise it sounds like a problem with the factory key/ignition system and I unfortunately cannot help you.
Old 02-03-2011, 11:32 AM
JDMitchell's Avatar
JDMitchell JDMitchell is offline
JDMitchell is starting off with a positive reputation.
I have been doing quite a bit of research on here about potential problems and the biggest cause of electrical gremlins is a leaky windshield seal. The GEM/fuse panel will get water in it and cause a short. Just my 2 cents.
Old 02-03-2011, 09:31 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The factory anti-theft system CANNOT cause an engine to stop running once it has started. You can rule that out. Wet GEM modules and fuseboxes typically manifest as intermittent or uncommanded accessory operation.
You might have a bad ground in the electrical system, but I'd replace the PCM Power relay first.
99 Expedition 5.4 L with Jet Performance module issue. COOLRAUL64 Computer Chips & Tuners 0 07-18-2015 09:35 PM
Anti theft help!!!! jerryholt67 Excursion - King of SUVs 26 02-15-2015 08:16 PM
1998 Expedition Rough Ride and Stall chandrabites 1997-2006 Expedition & Navigator 6 06-20-2014 05:36 PM
theft light killing car randomly wrathchild Escape & Escape Hybrid 9 12-05-2012 01:35 AM
'98 2.5/auto anti-theft starting issue RhondaBruce Ranger & B-Series 8 03-14-2011 10:19 AM
Tags
1999, anti, blinks, case, computer, electrical, expedition, factory, ford, light, lincoln, mode, navigator, reset, stalling, theft, transfer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
