1999 Expy not going to 2wd in A4WD
I have pulled the motor and the is switchinbg as it is supposed to. It will go into 4WD Lo and indicate such on the dash and will then switch back out and indicate A4WD on the dash but the front end is still locked in which is evident when having to make turns on dry pavement.
On the '99 the front axles,diff and driveshaft spin regardless of the setting. The only disconnect for the front drivetrain is in the t-case.
I would be more concerned to know what happens on the shift motor when you go from a4wd to 4hi, switching into 4lo is a little different than a4wd to 4hi. I would just make sure it isn't that shift motor or the switch before removing a t-case.
Thanx for the info will have to check this out.
I tried this as well as pulled #23 and neither of these made any difference. You can hear clicks in the t-case while switching from a4wd to 4hi and back to a4wd but the front end stays engaged. I appreciate all the suggestions so far but still frustrated.
I must apologize as my son just informed me that he did not test drive the Expy after pulling the fuse he saw that the shift motor wasn't working and assumed that it was not the problem. You and I both know what ***ume means. After he gets home we are goint to try the fuse situation again and then see what happens. Again I must say thanks.
