clunking noise from transfer case??? - Ford Truck Enthusiasts Forums
Old 02-02-2011, 07:58 PM
036.0stroke's Avatar
036.0stroke 036.0stroke is online now
036.0stroke is starting off with a positive reputation.
hey, my truck has started to make a clunk when i let off the throttle. i dont even have to push it that hard to make it do it. checked u joints and it has a dana 80 rear end so i dont think it would be that but who knows. if i go between reverse and drive it will do it too. any one know what it could be? 6.0 cc lb dually auto 4x4 239 000 miles
Old 02-02-2011, 08:02 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Try greasing the drive shaft slip joint
Slip joint regreasing
Old 02-02-2011, 08:05 PM
i just greased everything icluding the slip joint at the last oil change. think it could already need it? maybe its the grease im using? i use some stuff called mystery grease.
Old 02-02-2011, 08:12 PM
***** Emeritus
Have you checked the drive shaft center support bearing?
Old 02-02-2011, 08:15 PM
yea i can force it to move a little but i think its just the rubber flexing
Old 02-02-2011, 09:00 PM
got underneath it and watched when it was put between f/r and the drive shaft moves like almost half a turn before it clunks each way. does this t case have a chain in it?
Old 02-03-2011, 11:39 AM
i really need to get this figured out before it leaves me somewhere. does anyone know what else could be causing this? thanks
Old 02-03-2011, 12:10 PM
broncoformudv broncoformudv is offline
broncoformudv is starting off with a positive reputation.
The T-case does use a chain but it should only affect it when in 4 wheel drive since the chain drives the front output shaft for your front driveshaft.
Any vibration while driving?
Have you tried to wiggle your rear pinion yoke to see if it has play?
What about the rear output shaft on your t-case?
Clunk When Starting or Stopping - 2008 F-250CCSB4x4 scottjima 1999 to 2016 Super Duty 226 08-26-2016 03:37 PM
second to third gear clunk powerstroker04 6.0L Power Stroke Diesel 10 10-05-2015 12:00 AM
2003 Explorer - Clunk ??? saturn97sl1 Explorer, Sport Trac, Mountaineer & Aviator 3 01-29-2014 12:04 AM
Deceleration clunk Hallstate 1987 - 1996 F150 & Larger F-Series Trucks 4 10-27-2013 06:15 PM
Front End "Clunk Clunk Clunk......" MDSuperDuty 1999 to 2016 Super Duty 9 12-05-2011 08:37 AM
Tags
07, 2003, 60l, case, clunk, clunking, diesel, duty, f350, ford, noise, problem, problems, sound, suler, transfer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
