How much fuel do I use idling? - Page 2 - Ford Truck Enthusiasts Forums
Old 02-02-2011, 10:43 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
This may be off base, but here are some calculations:
Table below is from the PC/ED manual (misfire monitor):
Entry Conditions:
Entry condition.................Minimum.........Maximum
Fuel desired......................None............35 mg/stroke
Engine Oil Temperature.......50 oC............110 oC
Engine Speed (Low Idle)......600 rpm.........750 rpm
Vehicle Speed....................0 MPH...........1 MPH
Intake Air Temperature........-15 oC...........100 oC
Exhaust Backpressure Gauge...None...........50 kPaG
Injection Control Pressure Duty Cycle....0....50%
PTO off............................None..............N one
This seems to be between 120 degrees oil temp and full oil temp. It is at the initial low idle, not considering any "high idle mod".
Use 35 mg diesel fuel desired per stroke.
Assumption - 1 stroke = 1 revolution
Assumption - diesel density is 0.9 gm/cm3
(35mg x 750 rpm x 60 min/hr) / (1000mg/g x 0.9g/cm3) = 1750 cm3 of diesel used per hour
This is 0.46 gallons of fuel / hr
Maybe some wrong assumptions - hopefully someone will let me know if they are!
As I said earlier, the latest flashes will elevate the idle periodically (I need to re-read the TSB's to recall when and how much)
Here is an example of the thread that I recall seeing for the 6.0L:
http://powerstrokenation.com/forums/...t=18557&page=2
Old 02-02-2011, 11:00 PM
Benchwrench's Avatar
Benchwrench Benchwrench is offline
Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.
After the truck starts, the engine idles for about a minute or so then it automatically goes into a higher idle, is this high enough rpm for extended idle time?
I never looked at the tach to see just how much it's raised.
Old 02-02-2011, 11:09 PM
bismic's Avatar
I don't believe so. My recollection is that the typical strategy will raise it to 850...... but I need to check that out in the TSB.
ljutic ss's Avatar
ljutic ss ljutic ss is offline
ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.
The high idle kick in after 2 minutes varies rpm wise depending on outside temp. Example my truck goes to about 1,040 rpm when its around 30 or colder, but if its around 40 deg. it will high idle around 850 rpm.
Old 02-02-2011, 11:29 PM
bismic's Avatar
Quote:
Good info!
I believe the TSB I saw stated that the point that the elevated idle kicked in was actually dependant on either oil or coolant temp (not ambient temp) - IIRC it is oil temp.
Old 02-03-2011, 12:13 AM
ljutic ss's Avatar
Quote:
Originally Posted by bismic View Post
Good info!
I should have been more specific with the temps. I take my temp readings from a Edge insight, EOT/ECT when I turn the ignition on in the morning.
Old 02-03-2011, 12:33 AM
High Binder's Avatar
High Binder High Binder is offline
High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.
Good info!
FYI, the OEM high idle kicks off at 150F-ish.
Old 02-03-2011, 01:32 AM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
Quote:
Originally Posted by 2006powerstroke90 View Post
Well I usually let my truck warm up for about 20-30 minutes before I leave for work in the morning and before I leave work to go home.
Some people say I am crazy for leaving it out there running for that long wasting fuel....
I really don't think I am using that much?
How much would I burn per hour?
20-30 min is too long. That is wasteful. I feel that with "warm up" in mind. 10-15 min is the max. After that is is unneeded. I let mine warm up for atou 10 min and I use a block heater for 3 hours in the morning.
Old 02-03-2011, 10:16 AM
Kert0307's Avatar
Kert0307 Kert0307 is offline
Kert0307 has a good reputation on FTE.Kert0307 has a good reputation on FTE.Kert0307 has a good reputation on FTE.
I use the block heater(3.5 hrs on a timer) and let it idle for around 10-15min in the morning. This morning it was -5 degrees F out. Block heater got it to about 80 degrees. High idle mod for 12 min got it to about 150 deg F.
FYI my Bully Dog Monitor has the option for monitoring fuel in gal/hr. Low engine idle is around .5-.65 gph and high idle is 1-1.25 gph. When the engine first fires and is "cold" it will use about twice that for the first minute or so, then level off to the values I posted. I don't know how accurate the reading is though.
Old 02-03-2011, 10:26 AM
Jnas860 Jnas860 is offline
Jnas860 is starting off with a positive reputation.
This is a job for the MythBusters.
Old 02-03-2011, 09:59 PM
a711112a a711112a is offline
a711112a is starting off with a positive reputation.
Entry Conditions:
Assumption - 1 stroke = 1 rpm
The 6.0 is a 4 stroke, therefor it does not use fuel for every stroke ??????
Old 02-03-2011, 11:27 PM
mohle's Avatar
mohle mohle is offline
mohle is starting off with a positive reputation.
Quote:
Ditto that. You can idle it more, but then you might want to clean your EGR every week. Especially when it's actually cold. Let it idle for a few minutes until it goes to high idle. Then flip on your high idle mod.
  #28
Old 02-04-2011, 12:19 AM
_Me2_'s Avatar
_Me2_ _Me2_ is offline
_Me2_ has a good reputation on FTE._Me2_ has a good reputation on FTE.
Unless it is ridiculously cold, what's the point of idling for more than a minute or two and then driving easy until it's up to operating temp?
  #29
Old 02-04-2011, 02:24 AM
loubell loubell is offline
loubell is gaining momentum as a positive member of FTE.
Ditto. Why not a dynamic warm up?
  #30
Old 02-04-2011, 06:59 AM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
To much don't do it anymore
Injector Repair - Removing Oil and Fuel majorgator 1994.5 - 1997 7.3L Power Stroke Diesel 5 02-23-2015 07:51 AM
R134a, how much oil in comp jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 07-03-2014 12:24 PM
Carburetor inlet fuel leak Brnfree 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 06-10-2013 10:38 AM
MODS **idi Turbo** Breaker Breaker 3-3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 03-21-2012 03:32 AM
Block heater draw bashby Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 04-01-2011 11:02 PM
Tags
58, 60, cold, diesel, ford, fuel, gas, idle, idling, liter, long, powerstroke, truck, turn, v10, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
