1975 Ford Crew Cab Build - Ford Truck Enthusiasts Forums
Old 02-02-2011, 11:17 AM
DieselMike76 DieselMike76 is offline
DieselMike76 is starting off with a positive reputation.
Hi guys. Been posting over in the Engine Swap section. I thought the paint and bodywork section would be more appropriate for this.
Picked up a pretty rusty Crew Cab a few months back. Decided to swap in a Cummins. That's done now I'm on to Cab bodywork.
After tearing into this thing i realized it had a pretty bad resto job. Lot's of lead fill, bondo and rivets...
Here's the pics. I'm sure there's some pro's out there so any advice is welcome.
Here ya go...
Here's what I started with
Roof could be peeled off like tuna can. (Going to be putting a Ford Econoline corrugated roof on eventually)
Floor was held together by galvanized sheet metal and rivets, oh and some silicone ha ha
So I cut out all the bad metal and ordered my replacement panels.
Inner and Outer Rocker panels removed
Here's everything coming back together
This part has no repair panels available so this is strictly sheet metal work. I intend to have this look exactly like OE when finished.
I am using a 4.5" angle grinder, a 30" Brake from Harbor Freight, Hobart Handler 120 MIG and basic body tools here. Cleco's are a lifesaver to hold things in place.
Old 02-02-2011, 05:17 PM
Chaosracing's Avatar
Chaosracing Chaosracing is offline
Chaosracing is gaining momentum as a positive member of FTE.Chaosracing is gaining momentum as a positive member of FTE.
Looking good so far.....clecos are definatly good helper to have. I used to use small zip screws (still do on occasion) but when you have to keep taking off then putting back on the panel they make life easier.
If you have air, you might want to look at getting a angle die grinder with a 2" pad for Roloc pads to help with the welds though. Then you can use 26 grit sand paper to knock them down without all the extra heat a grinder brings. 1/4" Front Exhaust Air Angle Die Grinder - Grinders - Air Tools
Old 02-02-2011, 05:59 PM
Thanks,
I have the craftsman version with the 2" pads.
My problem is the compressor only pushes 6CFM so it puts quite a strain on my weekend warrior.
Miss my dual stage I had 10 years ago. Used to paint cars in the garage with that bad boy.
I use 36 grit like you said to keep warpage down. 22 ga steel kinda flexy.
Anyway this weekend making a parts run to pick up a '78 single cab, doghouse, and shortbed I picked up for $500.
The nice thing about these crews is they used many of the same panels the singles cabs did (except the middle section). I can use this as a donor to fix my cab.
Old 02-22-2011, 07:45 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Nice work...are you going to modify reg cab parts for the outer rockers?
I'm not even sure if thats possible but it sounds like a good solution.
Old 02-23-2011, 10:25 AM
The inner rocker is slightly different but the outer rocker is exactly the same.
The seam will be covered by the lower rear panel.
There is no good rocker repair panels that are as strong as the originals.
But in looking at the crew and standard cab you can see where there is basically a seam and they added a center section of floor to extend the cab. Up to this point they are the same.
The rear part of the crew is the same as the rear of the standard cab again the only difference being a seam where they joined the 2.
Almost done with the repair I'll be posting pics soon.
Old 02-23-2011, 07:52 PM
fordman75 fordman75 is online now
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
Looking good! You are doing some nice work.
Old 02-24-2011, 08:51 AM
ibleedblue1385's Avatar
ibleedblue1385 ibleedblue1385 is offline
ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.
Looks good.
Love the old crews.
Old 02-25-2011, 09:15 PM
I got some OEM outer rockers from Green Sales last summer if you need them.
Old 02-28-2011, 10:46 AM
Thanks,
I have 2 from my parts truck ill be getting to the rear doors soon. I'll let you know.
I need rear doors of anybody has an idea where some are available.
Old 05-26-2012, 04:16 PM
Biz77 Biz77 is offline
Biz77 is starting off with a positive reputation.
Anymore pictures from this restoration?
Old 06-11-2012, 08:15 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is online now
78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all
I have a nice rear door w no rust, but has a dent. Need to get it out of the garage.
Old 06-11-2012, 09:43 PM
How much for the door?
Old 06-12-2012, 05:42 PM
message me and we can figure something out
Old 04-15-2014, 04:14 PM
Well guys judging by the last time i posted its been a few years.
This little guy was a year and a half old when this whole thing started.
He starts kindergarten in 4 months. Yikes..
As with most of these projects the work took priority over posting.
Here's the update.
It's now at the painters getting final block sand and sealer.
Should have color by the end of the month.
Here are the pics so far.
Old 04-15-2014, 04:18 PM
A fellow poster suggested it would have been easier to buy a scrap cab and start from scratch.
In hindsight i would have to agree.
It took a donor cab, a metal fabricator, and a bunch of reproduction sheetmetal to get this cab like it is here.
It is probably 50% original sheetmetal.
Visit to Terry's F100 Parts- Nebraska dadgonebroke 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 02-10-2017 07:47 PM
My wiring nightmare... could use some help Aaron-71 1973 - 1979 F-100 & Larger F-Series Trucks 27 07-02-2015 02:53 PM
1975 Ford Crew Cab Build DieselMike76 Engine Swaps 33 05-03-2014 04:23 PM
Ford Emblem Failure........ jh225 6.7L Power Stroke Diesel 45 03-11-2014 10:38 AM
1972 351W Wiring Aaron-71 Electrical Systems/Wiring 5 07-22-2012 02:07 PM
Tags
1975, 1996, 75, cab, crew, crewcab, f350, ford, green, ord, resto, rocker, sale, seams, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
