True Ford Disc brake conversion? - Ford Truck Enthusiasts Forums
Old 02-02-2011, 01:31 AM
tazcliff's Avatar
tazcliff tazcliff is offline
tazcliff is starting off with a positive reputation.
Does anyone know if there are any disc brake conversion kits that use ford brake parts? No offense to the dark side guys but for me a ford needs to remain a ford
Old 02-02-2011, 02:14 AM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
ford truck/mustang
My 51 is part Mustang. 289/MII IFS/67 Mustang disk brake conversion in the rear. Can't get more ford than a MUSTANG.
Old 02-02-2011, 11:20 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Quote:
Most brake parts are made by companies other than the car or truck manufacturer anyway like Bendix, Wagner, Delco (altough, I suppose Delco is a subsidiary of GM), etc., so what difference does it make?
tazcliff's Avatar
Should have clarified my question a bit. Ford front disc brakes with stock front suspension
Old 02-02-2011, 11:35 AM
Guess I don't understand the distinction...
Old 02-02-2011, 06:26 PM
ewalt98's Avatar
ewalt98 ewalt98 is offline
ewalt98 is gaining momentum as a positive member of FTE.
I don't know if this is what the OP is thinking, but for me, it would be nice to be able to pull a part from a newer Ford to upgrade an older Ford, regardless of who the part manufacturer is. In the case of brakes, sure a caliper supplier will make a part for Ford, Chevy, Dodge, etc, but the configuration/bolt pattern and the like are often different, so in that sense, the parts are make specific.
I think the opposite is true for European cars, where you can swap many parts between makes such as Porsche, Audi, and VW - and find the parts for an older Porsche a lot cheaper by looking at VW parts.
In upgrading, I usually think make specific, and if that doesn't work, I don't have a problem going to other makes to accomplish the upgrade (though I have a problem with putting a Toyota steering box on my Ford... ) )
Old 02-02-2011, 06:35 PM
59JEEPSTANG's Avatar
59JEEPSTANG 59JEEPSTANG is offline
59JEEPSTANG is starting off with a positive reputation.
I agree with ewalt, I will be watching this. I thought maybe you could use something off a twin I beam, but upon further inspection the caliper brackets appear to be part of the spindle.
Paul
Old 02-02-2011, 06:48 PM
f100newb's Avatar
f100newb f100newb is offline
f100newb is starting off with a positive reputation.
You want something that is not a GM caliper and disk correct? I think the issue is most of what we see for upgrades and even swaps are done with and for GM parts. I for instance can find a complete package to put an LS1 into my truck but be damned to find one for an actual 4.6 or 5.4 FORD engine. Good Luck. and yeah the Built Ford Tuff with Chevy Stuff is no good for me either
Old 02-02-2011, 07:09 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
I don't believe that there is a direct swap of Ford parts - bearings, hubs, disk, calipers etc - that will fit the spindles in the 48-60 era - I've been looking for at least 10 years and haven't seen anything.
It seems a little excessive for something thats not a true restoration.
Old 02-02-2011, 10:05 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Quote:
Swapping parts between VW, Porsche and Audi is a little like swapping parts from Buick, Olds and Pontiac. They are all made by the same company, VW. It's a lot less likely parts from your Saab will interchange with a BMW or an MG.
The problem with using Ford calipers is the design of the mounting isn't swap freindly. They're large and bulky, and in many older applications it's part of the spindle which can't be used.
GM calipers are used by the aftermarket because of the ease and simplicity of the attachment. And they work good. They can be adapted by means of a simple bracket bolted to the spindle.
My understanding is the 5 on 5 1/2 rotors used in the straight axle conversion are Ford truck parts from the 70's.
Old 02-02-2011, 10:38 PM
lvin4jc's Avatar
lvin4jc lvin4jc is offline
lvin4jc is gaining momentum as a positive member of FTE.lvin4jc is gaining momentum as a positive member of FTE.
This is where i'm at with it too, I wanted the same as the OP but after looking into it, it's just not worth the hassle/cost.
A 5.4l swap would be awesome btw, but you're right all the mounting kits are for chebys, at least 90% of the ones i've seen are for bowties. Lame...
Old 02-02-2011, 11:21 PM
Mervy49's Avatar
Mervy49 Mervy49 is offline
Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.
Here is a place to check for Ford rotors for f-1 and f100's
http://www.magnumaxle.net/MagnumAxelCatalogWeb.pdf
Old 02-02-2011, 11:48 PM
fordman75 fordman75 is online now
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
There use to be a kit that used 60's Mustang calipers but I haven't seen them for a while.
Before I decided to go 4x4 on my truck I was going to adapt a pair of Late model Mustang Cobra PBR aluminum dual piston calipers. It takes fabricating a new caliper adapter mounting bracket though.
I feel the same as the OP. For the back brakes on my project I want to use all Ford parts. All the aftermarket kits use a cheap gm or caddy caliper. So I'm adapting the set up off a 99 E350 Ford van. It requires welding new mounting flanges on the rear diff but it's worth it.
Old 02-02-2011, 11:56 PM
Mervy49's Avatar
I prefer to keep my old Ford -Ford, actually I insist on it. I'm presently surfing all around to find a Ford disk/ rotor set up for my f47, 5.5 on 5.5 spindles
Old 02-03-2011, 10:57 AM
tazcliff's Avatar
I respect all of your opinions but ultimately its my truck to build to my personal taste. I would never criticize someone for wanting to use a Chevy drive train or a jag front end even though I would never consider such swaps. In my eyes like Mervy and others have said my preference to keep my ford, ford.
Speedway disc brake conversion moose79 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 03-26-2016 10:07 PM
Drum to Disc brake conversion using Explorer disc brakes FLJ Brakes, Steering, Suspension, Tires, & Wheels 4 09-08-2015 01:42 AM
Disc brake conversion kits Walwal44 1987 - 1996 F150 & Larger F-Series Trucks 27 11-25-2014 01:41 PM
Ford 9" disc brake conversion 1967 F100 HogTied 1967 - 1972 F-100 & Larger F-Series Trucks 26 11-19-2014 02:43 PM
disc brake conversion kodiak14 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 12-09-2013 12:19 PM
Tags
100, 1947, 1948, 1951, 1960, brake, conversion, disc, disk, f1, f100, f250, ford, kits, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
