Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Iowa Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
  #1 (permalink)
Old 02-01-2011, 11:03 PM
diakonospat diakonospat is offline
Garage is empty, add now
diakonospat is starting off with a positive reputation.
diakonospat@msn.com
Question diakonospat
New owner of 2003 F250 CC 4X4 Lariat V10. Not overly mechanically inclined but, I can turn on the igniton, drive, and seek help from a good mechanic when I need to. The owners manual on fuel said not to use methanol, which I know to be a wood alcohol. Is ethanol (here in Iowa is corn alcohol and same as alcohol used in alcoholic beverages) safe to use for the fuel system and engine? Plan to begin pulling our 30' travel trailer with it in the Spring 2011.
  #2 (permalink)
Old 02-02-2011, 08:14 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Methanol and Ethanol are very much different. I have run higher concentration of Ethanol with no ill effects. Been running E10 since it was released back in the 80's with no extra fuel issues. I don't have that new of a truck, but my mom's 02 Buick Lesabre has run most of it's 340,000 miles with some kind of ethanol in it. Only time it doesn't is when it isn't available or priced higher.
Oh, and welcome! I work in CR, live sw of town, just past the Amanas.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 02-21-2011, 08:20 PM
diakonospat@msn.com
Having moved from a V6 to a V10 for the first time, I am adjusting to a very thirsty engine, but looking for our trips pulling our RV over the Rockies in the spring and the Appalachians in the summer this year. On the road here in Iowa, without pulling our RV, on the Interstate I am averaging 12.2 mpg uphill, 12.5 mpg on the flat, and 12.8 mpg on the down hill. I have heard I should do about 10 mpg average pulling my RV. Any thoughts on increasing mpg?
  #4 (permalink)
Old 02-21-2011, 08:25 PM
fellro86's Avatar
1978 Ford F-150
Free flowing intake and exhaust are key, otherwise a programmer chip might help. Overall though, it is a big cube engine, and towing, it isn't going to get much better I'm afraid. My 88 with the 351W doesn't do that well. It also has a lot of miles, and the gears aren't good towing gears.
__________________
  #5 (permalink)
Old 02-21-2011, 08:37 PM
diakonospat@msn.com
Thanks fellro86. Thought that last post was wishful thinking. I guess I'll just have to pay the man at the pump. Knew it when I bought it but, one can always dream. Thanks again.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
