Need Help Got Codes
Need Help Got Codes
I need some help. I am out of town for work and got a call from my wife. She said on the way to take our daughter to school our expedition started to sputter like it was running out of gas. Then the check engine light came on. I had her take it down to the parts store to have the codes run. She said they are PO 300 (random miss fire) and PO 304 cylinder #4. She also said she is getting a bad sulfur smell. Any ideas?
Let me guess . . . if this truck has the 4.6L engine and has coil packs it might be an older model, like 1997 or 1998? What shape is the fuel filter in?
Misfire can also dump unburnt fuel into the cat and cause some rotten eggs.
Might want to start with attaching a fuel pressure gauge to it to see what kind of pressure its putting out when it acts up. And if the pressure is good might want to check the fuel volumn that its putting out.
Random misfire could be caused by a fuel supply issue. And if the wife says it acts like it's running outta gas, better check that out first. Was the tank running on empty?
Those same symptoms are mostly a COP/plug issue......most likely when they changed the engine out they used the same COPs that were in the old engine
Everybody wants to think its a fuel issue at first but w/ that 5.4 its most likely a bad COP/plug
wouldnt hurt to change the fuel filter anyway..its prob due
sharpcar
1997-2006 Expedition & Navigator
03-22-2008 09:54 PM
