broken vent window piviot
Replaced the pivot on the 65 several yrs. ago which required making 1 workable vent window out of 2. It requried carefully ginding the ole rivets out and replacing with new rivets. Found seating the rivets to secure the pivot to the frame can be a task. Seem to recall the Rt. and Lf. pivots are not interchangeable. Don't believe the frames are interchangeable after 65, not sure about the pivots.
Have not noticed the vent window accessories in any of the Ford parts supplier's catalog. In reassembling the 65, purchase many of the fasteners from restoration specialty, noticed in their catalog they list vent window pivots and arms but noted to contact them to determine if item meets your application.
Page 220:
RSSI Services Page
Page 220:
RSSI Services Page
Can't recall which v window that was repaired but starting to have difficultly closing driverside so when weather permits intend removing and if it's the pivot arm again, if so, certainly look into having it mig welded, thanx for the info.
C1TZ8121608B .. Right Vent Frame / Obsolete
HEMINGWAY MOTOR CO. in Andrews SC has ONE = 843-264-5243.
MANDERBACH FORD in Temple PA has ONE = 610-929-3683.
High Buck! BOB ALLEN FORD in Overland Park KS has 7 = 800-676-0675.
GREEN SALES CO. in Cincinnati OH has 14 = 800-543-4959.
C1TZ8121609B .. Left Vent Frame / Obsolete
No Ford Dealer or obsolete parts vendor has any.
These two frames fit: 1961/66 F100/1100 // 1963/69 N/NT500/1000 // 1967/69 F800/1000.
All these trucks use the same parts, cuz the doors are essentially the same (The N Series use different R/L door shells, otherwise...everything is the same).
On the R&L lower pivots is one pivot stop (COAB6422292A); Two flat washers per side (356425S); a nut (353618S); and a coil spring (B5A7022926A).
The coil spring weakens, allowing the vent frame to flap around. These parts fit all sorts of myriad applications besides these trucks and can be found NOS.
I found over 600 (!) of the springs...GREEN SALES CO. has 385.
turbo2256d
02-13-2016 05:01 PM
rpaxton939
04-05-2015 10:05 AM
mt54
09-07-2005 12:49 PM
red83150
12-09-2002 02:13 PM
ranger pat
02-12-2002 05:37 PM
