97 F250-7.3 litre..check engine light - Ford Truck Enthusiasts Forums
Old 02-01-2011, 10:13 PM
kevinrea kevinrea is offline
kevinrea is starting off with a positive reputation.
hi guys,
so, my check engine light is on for about a month now.
i took it over to a mechanic and he scanned it and it came back with
P1284 code.., he cleared it twice and it still came back.
we looked it up.., but we were not sure if it could just be caused by the pcm having a chip installed on it ?
any ideas ?
thanks,
Kevin Rea
Old 02-01-2011, 10:24 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Quote:
Originally Posted by kevinrea View Post
hi guys,
any ideas ?
thanks,
Kevin Rea
May want to see if the ICP sensor is seeping oil ..
Quote:
Z21 DIAGNOSTIC TROUBLE CODE (DTC) P1284
DTC P1284 indicates that a ICP circuit failure was present while trying to perform KOER Cylinder Contribution Self Test.
Perform KOEO On-Demand Self Test.
Old 02-02-2011, 12:11 AM
what do you mean seeping oil ?
and, where is the icp sensor ?
thanks,
kevin
Old 02-02-2011, 07:08 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
He means to unplug the icp and see if there is any oil in the connection. Here's a pic for you Kevin
Old 02-02-2011, 03:04 PM
ok.. thanks !
kevin
Old 02-02-2011, 03:42 PM
thanks guys !!
I think I found it..
When I went to look at and pull the connection on the ICP, it was broken off, that is the top part of the icp was broken off.. so , I ordered another one.. we'll see if that fixes it.
I might have laid the new ac compressor on top of it when I was changing it., that might have broken it.
Thanks very much guys !!!
kevin
Old 02-04-2011, 11:24 PM
What are the results of ICP Sensor disconnected ?
hey guys,
so, what can happen, that is, what systems or gas mileage or what ever could be affected if the ICP sensor is not connected ?
I noticed that onthe last trip my gas mileage was crap.. about 9 mpg instead of about 21.
thanks,
Kevin
Old 02-05-2011, 06:51 AM
mq1shooter's Avatar
mq1shooter mq1shooter is offline
mq1shooter is starting off with a positive reputation.
I'll try this one...other's will correct me if wrong. Disconnecting the ICP will tell the PCM to default idle rpms...It should start and idle....but that should be all it will do...Anyone else? Am I close?
Old 02-05-2011, 07:08 AM
Shooter, I think the pcm will go to default like you mentioned but it will run, just not ideal as the pcm is just guessing what to do as it reads the icp, then passes the info to the ipr.
Old 02-05-2011, 09:16 AM
mq1shooter's Avatar
So the PCM must be sensing the Pedal Position and just giving a WAG as to what the IPR should be at? I would think that would be a very unresponsive Powerstroke, with limited power....just wondering.
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
hi guys,
any ideas ?
thanks,
Kevin Rea
Kevin, if you add a signature explaining your truck you won't have to write it each time and helps others help you.
year, model, miles,mods and so on
Old 02-05-2011, 01:24 PM
what my truck has been doing without the icp connected
Hi guys,
well my truck has had its check engine light on for over a month now., which means that my icp has been disconnected.
there is no power loss or wierd running what so ever.., it just gets really bad gas mileage.
on the part of the signature for my posts.. i have had a signature on in my cpanel, but it does not come in.... is there some way to include it in my posts ?
it looks like this.
Kevin
Old 02-05-2011, 04:20 PM
Copedawg's Avatar
hmmm there should be a box somewhere to include it in every post
Maybe someone else can show you/us
Old 02-05-2011, 10:39 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
From what I understand the motor will run with the ICP unplugged but will not run if the IPR is unglugged. Correct me if I'm wrong.
Old 02-06-2011, 07:35 AM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar has a good reputation on FTE.rodneywar has a good reputation on FTE.
you are right it will default with the icp disconnected but wont run with the ipr disconnected cause there is nothing to control the high pressure oil flow to the injectors
Baffling Problem Canadian7.3 1994.5 - 1997 7.3L Power Stroke Diesel 4 10-22-2015 08:04 PM
'02 4.6L "Low Oil Pressure" quick35th Explorer, Sport Trac, Mountaineer & Aviator 6 05-09-2013 10:04 AM
very rough surging idle HELP... rlwilson2 1987 - 1996 F150 & Larger F-Series Trucks 8 01-06-2012 12:43 AM
Transmission Temp Sending Unit FI460 1999 to 2016 Super Duty 3 04-09-2011 12:53 PM
Check engine light egr valve flow problem 1998eddiebauer Explorer, Sport Trac, Mountaineer & Aviator 10 06-22-2005 11:23 PM
Tags
09, 60, 73, check, demand, diesel, duty, engine, f250, ford, headlamp, light, p1284, super, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
