Main Bearing Spacers - Ford Truck Enthusiasts Forums
Old 03-10-2003, 05:10 AM
Quantrex Quantrex is offline
Quantrex is starting off with a positive reputation.
Somebody asked me if they made either spacers or thick-wall main bearings to fit the 302 crank into a 351W block, much like what is offered to put 350 Chevy cranks in a 400 Chevy block. Anyone heard of such a thing?
Old 03-10-2003, 11:48 PM
TMI's Avatar
TMI TMI is offline
TMI is starting off with a positive reputation.
We have installed 4-bolt splayed caps on 351W before and have done a couple with 351C main size. They are easy to get spacers for and I like putting the caps on because there is only a spacer in the block half of the middle 3 main, since the caps we use are the correct size for the 351C bearing.
As of lattely I picked up a set of caps that are for a 351W and uses 302 main size. These we will have to make our own spacers.
Ford SVO catalog has a kit for 351W to use 302's in. I think it includes caps, bearings and spacers.
Old 09-30-2011, 01:37 PM
Svendingo Svendingo is offline
Svendingo is starting off with a positive reputation.
I know this is dragging one back from the dead, but I am looking for 351-302 spacers/bearings and having a hard time finding them.
292 C-700 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 2 08-25-2014 12:34 PM
lower crankshaft bearing sizes???? trevorrules General Automotive Discussion 1 04-11-2014 11:30 PM
Raising the block to replace 460 motor mounts & rear main seal..? Chevy Guy Gone FORD 1987 - 1996 F150 & Larger F-Series Trucks 5 10-30-2013 08:47 PM
FE crank in an FT engine? tylstruck FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 15 10-10-2009 08:54 AM
Cracked DOVE A Block$#?&*(! broncman Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 05-17-2006 02:30 PM
Tags
302, 351w, bearing, bearings, block, cleveland, crank, crankshaft, ford, kit, main, spacer, spacers, svo, thick, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
