BIG donaldson oil filter install
This was the best I could do with it being 2 degrees outside and black nasty water dripping off my truck everywhere. I just got back from a trip to town.
There is more room around it than you can see in the picture. Like I said a good half inch to the crossmember. It's not gonna hurt it. The bottom hangs about an inch lower than the oil pan which also won't be a problem. Anything that wants to hit it has to go through the differential first.
Looks like the ELF7405 is the best you can get.
Some other stuff I found:
ELF7405 crosses to WIX 51792XD for $32:
Type: Full Flow/By-Pass
Media: Wire/Glass
Height: 12.184
Outer Diameter Top: 5.342
Outer Diameter Bottom: Closed
Thread Size: 1 1/2-16
By-Pass Valve Setting-PSI: None
Beta Ratio: B2=5
Burst Pressure-PSI: 290
Max Flow Rate: 28-30 gpm
Nominal Micron Rating: 35
WIX 51792 is $23:
Type: Full Flow
Media: Wire/Glass
Height: 12.184
Beta Ratio: 2/20=3/10
Burst Pressure-PSI: 280
Max Flow Rate: 28-30 GPM
Nominal Micron Rating: 5
The 51792 and 7192, $15:
Type: Full Flow
Media: Paper
Height: 12.184
Beta Ratio: 2/20=8/21
Burst Pressure-PSI: 300
Nominal Micron Rating: 19
Media: Wire/Glass
Height: 12.184
Beta Ratio: B2=5
WIX 51792 is $23:
Type: Full Flow
Media: Wire/Glass
Height: 12.184
Type: Full Flow
Media: Paper
Height: 12.184
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Where did you find that info at? It's got lots of errors in it. It says this ones nominal micron rating is 35. It's 10 according to donaldson. The cross to wix filter is double that. The only similarities between the two is the size.
This was the best filter I could find anywhere for it though. It's supposed to catch everything 10 mic and bigger and filter down to 2 mic but not each pass. 10 mic was 99. something efficiency I think. Donaldson doesn't like publishing the specs on it anywhere and it's all very hard to find. It seems like every website out there has different info on it too. It's made for a Cat so having some experience manufacturing parts for them I know it would not be used on them without having the very best filtering ability.
#28
I don't remember now, I did a search for oil filter cross reference.
I was trying to find a place to buy that Donaldson filter but didn't have any luck.
__________________
#29
#30
Straight from the Donaldson site:
15 micron @ 99% efficiency
https://dynamic.donaldson.com/webc/W...tml?item=80882
Since I don't know of a local source yet, I picked up a set of six off of fleaBay shipped for ~$27/ea.
If the Cat shop is $30, I figure that's an okay deal. Especially since I was paying ~$22 for the Wix Gold.
Looking forward to installing this bad mammah-jammah.
