Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-01-2011, 04:55 PM
Cage Fighter Cage Fighter is offline
Garage is empty, add now
Cage Fighter is starting off with a positive reputation.
TPS Code 53
I have a 1989 F-250, 351W with C6 trans. The vehicle was parked for two years with idle problems. I checked the codes and had EGR and TPS codes. Replaced the EVR, EVP and EGR valve along with hoses. Replaced the TPS, cleaned the IAC and replaced IAC and TB gaskets. Still have code 53. Checked the TPS resistance at TP SIG and SIG RTN with 5680 ohms at idle and 728 ohms WOT. Back probed the TPS connector and had 5.03 volts at idle and WOT. Vehicle starts with high idle that steps down and then stalls. If I hold the throttle briefly it will idle and run fine. CEL is on during this time. On occasion, at around twelve miles of constant driving the idle will "change" and the CEL will turn off. Any help would be greatly appreciated.
  #2 (permalink)
Old 02-02-2011, 02:05 PM
rla2005's Avatar
rla2005 rla2005 is offline
2004 Ford Excursion
rla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to all
Sounds more like you measured the VREF signal instead of the TPS signal back to the PCM. I always use voltage values when measuring a TPS.
  #3 (permalink)
Old 02-02-2011, 03:57 PM
TexasGuy001's Avatar
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Since there is already a new thread on Throttle Position Sensors, I thought I'd add to it. When replacing the TPS are you supposed to put dielectic grease on it before installing?
__________________
1995 F-150 XLT 2WD 5.0 4R70W 3.55 LS (awaiting 5.8 swap)
1965 Mustang 302 T5
PICTURES AND INFO IN GALLERY
http://www.youtube.com/watch?v=KF7soIRbh9M
Texas Chapter
Fix It Up Don't %$@# It Up
  #4 (permalink)
Old 02-02-2011, 04:06 PM
rla2005's Avatar
2004 Ford Excursion
I do put some on the connector to help keep moisture out.
  #5 (permalink)
Old 02-02-2011, 04:33 PM
The old one had some on the part the mounts on the throttle body.
__________________
1965 Mustang 302 T5
Texas Chapter
  #6 (permalink)
Old 02-02-2011, 04:34 PM
Hey Cage Fighter, This may help you some.
YouTube - Testing a Ford 5.0L throttle position sensor
__________________
1965 Mustang 302 T5
Texas Chapter
  #7 (permalink)
Old 02-04-2011, 12:37 AM
Texas Guy, thanks for the link. I'll give it a check tomorrow and see what I get. I had considered that there might be a problem with the connector and this should confirm or eliminate.
  #8 (permalink)
Old 02-04-2011, 06:06 PM
OK, ran the tests according to the video and all was fine until the SIG RTN. Should have had approx. 1.0V at idle and had approx.10mV with no change at WOT. It looks like I might have a short somewhere.
  #9 (permalink)
Old 02-05-2011, 08:10 AM
rla2005's Avatar
2004 Ford Excursion
Minor correction, the Signal Output (Not Signal Return) in the video was ~1.0VDC at closed throttle throttle then progresses to ~4.5VDC at WOT. FWIW the closed throttle voltage can be anywhere between 0.6 - 1.0 VDC.
You said you measured the TPS output with an Ohm meter in your first post. Did you ever look at the resistance from the VREF wire and Signal Return and/or Signal Output? The TPS could be open internally.
Tags
1986, 53, 92, bronco, code, engine, f150, f350, ford, meter, ohm, position, sensor, testing, throttle, tps, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
