Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > California, Southern Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
California, Southern Chapter Join Chapter, Leader: wpnaes
  #1 (permalink)
Old 02-01-2011, 01:24 PM
SteveBricks's Avatar
SteveBricks SteveBricks is offline
2006 Ford F-250
My Garage
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Diesel Smog Check
Had my '06 tested today @ Peng's 76 on Carson & Cherry in Long Beach. I think it took the guy longer to input the info into the computer than it did to do the actual test. Here's what he did:
1) Rev the motor three times while an assistant checked for smoke
2) Crawl underneath and check for the cat (just looked at it, didn't tap on it)
3) Plug hand held scanner into the OBD II port
4) Poke around under the hood for a couple of minutes
15 minutes, 50 bucks lighter and I was out the door with the certificate.
__________________
'06 F250 6.0 / '94 F350 7.5
Regional Chapters Moderator
SoCal FTE
Join our Chapter *HERE*
9/21/54 - 9/25/09
  #2 (permalink)
Old 02-01-2011, 04:53 PM
orng1's Avatar
orng1 orng1 is offline
Garage is empty, add now
orng1 has a good reputation on FTE.orng1 has a good reputation on FTE.orng1 has a good reputation on FTE.
LOL That's a stupid way for Ca to make $15. Just add it to my registration instead, I'll put the other $35 into the economy myself. I'll be going in for smog next week...
  #3 (permalink)
Old 02-01-2011, 05:22 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
2006 Ford F-250
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Bill Pounds
Quote:
Did you remove your custom tune?
__________________
Folks call me Bill. Why, yes, it is a 6 liter. Your jealousy is showing.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back (w/CAT),Edge Insight CS,Blue Spring,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto,'08 Diff Cover,Upfitters Retro-fit,Coolant Filter,Custom Man Steps,Keystone 2011 Cougar 278RKSWE,2012 Fusion SE
  #4 (permalink)
Old 02-01-2011, 06:46 PM
2006 Ford F-250
My Garage
I put it back to stock a few days ago. With the tune installed I'm sure it would fail the smoke test.
__________________
SoCal FTE
9/21/54 - 9/25/09
  #5 (permalink)
Old 02-01-2011, 07:15 PM
T8R's Avatar
T8R T8R is offline
T8R has a very good reputation on FTE.T8R has a very good reputation on FTE.T8R has a very good reputation on FTE.
Hmm... that's a good idea. I've got a 'smog' tune... but haven't actually ever run it to see if it smokes. (Have 6 mo to make sure everything is in order.) Can their obdII scanner detect the presence of a chip, even if it's running a detuned program? I kept the cat off my stock exhaust just in case - need to make a 'test pipe' adapter for it, although I thought the '99 shouldn't require it. I'll check with one of the cooler local places before then and report in here in case it helps anyone else.
Once I get flanges on the stock cat, maybe with some adapters for the MBRP - happy to loan it if someone's in need. (The only 'relatively affordable' ca legal cats i've heard of are Magnaflow... and I've yet to see a vehicle run right with one of those things in the way of the exhaust. )
I'd really really hate to have to find a 'spare' set of stock injectors to pass smog. I'd rather get an east coast DL, use a relatives address and register the truck somewhere else.
__________________
RoB
F250 2WD Crew w/ bigger torque converter, ISSpro guages
Recently installed: 6637 intake, MBRP 4" exhaust, Riffraff High Pressure Crossover, Garrett Power Max BB turbo, Stage 2 Single Shot Injectors and DP tuner. Thanks to Clay at Riffraff. The cup holders previously mentioned in my sig. are going to have to wait.
  #6 (permalink)
Old 02-01-2011, 07:31 PM
2006 Ford F-250
My Garage
Quote:
I'm sure that's going to depend on where you get it tested, and what the knowledge level of the tester is (or if he cares, for that matter) and what he uses to read codes. This guy just used an over-the-counter code scanner...never hooked it up to a computer.
The place I went to is a test-only facility. I figure they hadn't seen too many diesels there, because he was referring to his book quite a bit.
__________________
SoCal FTE
9/21/54 - 9/25/09
  #7 (permalink)
Old 02-02-2011, 09:13 AM
bpounds's Avatar
2 bit Californian
2006 Ford F-250
Bill Pounds
If it had a cat from the factory, it needs it. As I understand it, some '99 did, some didn't. There should be a sticker under the hood, usually on the radiator support, and it will say Catalyst or Non-Catalyst.
Seems to me there would be a black market for new stickers.
__________________
  #8 (permalink)
Old 02-02-2011, 02:11 PM
turbohunter's Avatar
turbohunter turbohunter is online now
1963 Ford Thunderbird
My Garage
turbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to behold
Mornin Guys
Haven't had to smog the '08 yet but it sounds like a switchable system will be easy to work out.
My mileage for a diesel is horrible, so I can't wait to delete dpf.
Figured I'd get to it after 100k is reached.
Any thoughts on who would have a nice system besides the obvious Banks
  #9 (permalink)
Old 02-02-2011, 02:25 PM
2006 Ford F-250
My Garage
I see a lot of people using Spartan and KEM for their DPF deletes and tunes. I believe Elite is in that game also.
__________________
SoCal FTE
9/21/54 - 9/25/09
  #10 (permalink)
Old 02-02-2011, 02:30 PM
My Garage
Muchos gracias
  #11 (permalink)
Old 02-02-2011, 04:13 PM
orng1's Avatar
Why wait, do ir now and save the money on fuel. A full tank is over $100, you'll be able to make that back in what you save on fuel.
__________________
00 F250 5.4L K&N stock box folter, 257k miles.
01 F250 7.3L DP Tuner, Airaid intake, Magnaflow 4" turbo back, 88k miles. Bob
<img src="<a href=http://api.photoshop.com/home_e202e8e80efb4a1696c4980e2d094cf5/adobe-px-assets/c71a8ac8ad5f4072a1981a2a389f6f04 target=_blank>http://api.photoshop.com/home_e202e8...981a2a389f6f04</a>" width="450" height="150"/>
  #12 (permalink)
Old 02-02-2011, 04:24 PM
My Garage
True enough.
Just don't feel like taking the chance on a drivetrain warrantee ( read expensive ) and being turned down cause they bust me by detecting the reprogram on the computer.
From what I read they are pretty good at that.
  #13 (permalink)
Old 02-02-2011, 04:41 PM
My Garage
On that subject
Steve just turned me on to Spartan Diesel today.
On there site they claim that their program cannot be detected, so a little more detective work is warranted there.
Tags
60, 76, california, check, detuned, diesel, f350, ford, pengs, smog, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
