Now,I am REALLY stumped!!
When you check the spark at the coil you should be able to jump the spark from half inch without a problem the closer the bluer/whiter the spark should get, if its close and your spark is orange your ignition coil maybe to week to start the engine as well. Just not sure how you tested this let me know how it goes, and testing the map sensor you need an adapter MAP/BARO, and a volt/ohm meter when connected KOEO you should have 4-6 volt reading for supply voltage. Hope this helps.
I just pull a plug wire, stick a long insulated screw driver into the boot and then hold the side of the screwdriver close to a ground while someone turns the vehicle over....should jump the gap to ground if you are getting a good spark. Motor only needs compression, fuel, air, and spark at the right time to fire. I would say you have a spark issue if starter fluid does not start your truck, or attempt to start your truck, unless you have like 0 compression in all cylinders. Have you checked any codes?
Here is a REALLY good checklist for an EFI no start. Was written for the 5.0 crowd, but pretty much applies to our trucks as well.
How to Solve an EFI No Start
You said the spark plugs smelled like gas, Good chance they fouled out and with weak spark thats a possablity.
Take all spark plugs out, disable the fuel pump(impact switch is good for that) so when cranking engine you don't flood the engine again, pull off the TFI connector so spark won't happen(see below). Spin engine over few times and watch to see what blows out, a really flooded engine with spout out the left over fuel(make sure no sparks near by). Go wide open throttle too during cranking, that should clear anything left in the intake manifold.
After engine clears that test. rehook the TFI back up and put new spark plugs into the plug wires and place them so they are all visiable at the spark gap. Usually dusk is better to watch the spark gaps. Watch plugs and if all are sparking, reinstall the plugs and wires. Then try some starting fluid to see if it fires off on it. If it does fire off on starting fluid, then reset the fuel impact switch to get the fuel pumps running and try starting the engine. Hopefully this will get it running.
I did this on my 89 F250 when it flooded out on my Wife, not sure what happened to cause the flooding.
Pressing the throttle to the floor cuts the injectors and no fuel will flow...do this as you turn the car over and it should clear out fuel. You can pull a fuse or relay and diable pumps if necessary, much easier than getting behind the kick panel. I would follow the steps of my link....it's very good information.
Ok,worked on it for a few mins tonight to check spark in the dark. I also tried starting fluid,still no start there. There is good spark at the coil,it jumps a 1/2 inch gap on the spark tester. At the spark plug is where the problem is. I got very little spark,wouldn't even jump a 1/4 inch gap and was very weak and orange looking. what would cause that?
#28
#29
When my MAP sensor failed the truck would start but not idle or run very well. Codes were set for a lean mixture but nothing for the sensor itself. When I disconnected the vac line from the MAP sensor the engine would run better and idle and a code was set for the MAP sensor. I replaced the sensor with a JY part and it ran great.
Check your wires, especially the coil to cap wire, with an ohm meter and see what you get. The cap and rotor could be gone but its usually visible with burn marks, cracks, or carbon tracks.
BTW I have an old spark plug with a ground clamp that I use to test spark. The gap is set at .050
regards
rikard
regards
rikard
#30
