Where does hydraulic fluid go? The front diff in the tractor was 2.75 quarts low, only takes 4.7, and the main resevoir was a gallon low, out of 6.8. Where does it go?
hello people.today i will be shoveling snow off the horse trailer. its not going to collapse but i want to keep it clear in case she needs to take it somewhere, especially with the threat of another 18" being added to what we have already.
air bubbles working out of the system if your tractor is new, and you can never trust anything to be properly filled from the factory. actually, you can trust it to be low.
That's probably true. I just had the first major service done 200 hours ago, and all the fluids were changed. The diff is a drain and fill, and I never see anything leaking, so I don't know. It is what it is.
