Ok to get rid of the cat on a 7.3L in Eastern WA?
After getting my intake and tires done on my 1997 F350, I'm looking to do an exhaust system on my 7.3L diesel. From what I understand there are really no emissions testing on the rigs in the Tri-Cities area. Would it be ok to get rid of the cat on my rig or should I keep it?
I don't see any reason why not - I removed the cat from my Bronco. Just be prepared to put a cat back on if emissions testing becomes mandatory. I'm not going to hold my breath, because I'm sure it will be a while before it's required. The infrastructure and manpower is just not there yet. However, it's only a matter of time... after all, we do live in what I like to refer to as "Little California."
Though it may be true, I'm not going to run a cat until I HAVE to. When I had it taken off, it was choking my truck to death, and couldn't afford a high flow. I still can't afford one, but when I have to, I'll get one. Too bad because I also want to do cam/lifters, intake, header, carb, ignition upgrades; all of which will either heavily alter or remove the emissions equipment. Looks like I'll be boxing up and storing that stuff when I do that.
Thing is - on a truck like mine, the original emissions equipment didn't do much along the lines of reducing emissions (at least at the level that vehicles do now), so I figure why bother? Chances are that with the changes I plan on making the engine will run smoother, have more power, possibly get better economy (wish), and probably won't run as fat as it does now, since at idle the exhaust is just full of that unburnt fuel smell. Oh well... when that time comes, hopefully it'll be old enough for Collector's Plates! /rant
Sorry for hijacking this thread, just felt that I had a point to make even if I didn't accomplish that. :/
93_Big_Rig
04-23-2007 08:46 AM
alk3myst
1978 - 1996 Big Bronco
13
09-05-2003 09:31 AM
