Power Distribution Box Under Hood - Ford Truck Enthusiasts Forums
Old 01-31-2011, 08:15 PM
urzu007 urzu007 is offline
urzu007 is starting off with a positive reputation.
I blew a fuse for my trailer charging circuit last week and and had a heck of a time getting the cover removed from the Power Distribution Box/Fuse box that is located under the hood. I ended up just flexing it and getting my hand in there to change the fuse. Does any one have a trick or know how to remove the cover?
Old 01-31-2011, 09:20 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is offline
EpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud of
You have to remove the coolant line that comes around the back side of the degas bottle. Simply pinch and pull to disconnect the hose. Then remove the other side of the hose from the pinch connector on the back side of the degas bottle. Pinch the holder and pull straight up. That gets the hoses out of the way and you can remove the plastic cover.
It's still a bit tight, you have to lift the side and pull up and then out. I mentioned this and showed the hoses in the airbag installation video.
Old 01-31-2011, 11:09 PM
Thanks! I was avoiding that video because I want to install air bags on my truck but don't have the money yet. Watching the video makes me want them more. I figured there was a trick I was missing to getting the cover off.
Horn relay. Which one is it and how to test? f150crewcab Excursion - King of SUVs 8 10-07-2015 04:04 PM
how to open under hood fuse box? georgeda Escape & Escape Hybrid 0 06-05-2015 01:55 PM
2008 Escape A/C issue Jgbxfd Escape & Escape Hybrid 3 07-07-2011 08:27 PM
97 f150 blowing air bag fuse under the hood dbcooper 1997 - 2003 F150 1 10-14-2010 06:31 PM
Cruise control problem WarOzz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 07-23-2010 08:12 PM
Tags
97, box, cover, distribution, duty, f150, f350, ford, fuse, fusebox, hood, power, remove, super, trucks, underhood
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
