49 truck with 4.6 modular motor-IT'S ALIVE!!! - Page 2 - Ford Truck Enthusiasts Forums
Old 05-04-2011, 01:14 PM
hellfirejim's Avatar
hellfirejim hellfirejim is offline
hellfirejim is starting off with a positive reputation.
First is congrates on getting it fired up, what a great feeling. Question, have you wired in your inertia switch to shut off the fuel pump if you get hit?? They are in all EFI cars now. I put one in a car that had an electric fuel pump.
As for your body work skills, far superior to mine. Nice work and keep the pictures coming.
jim
Old 05-04-2011, 08:49 PM
gregstith's Avatar
gregstith gregstith is offline
gregstith is gaining momentum as a positive member of FTE.gregstith is gaining momentum as a positive member of FTE.
Thanks. Yeah, I have the inertia switch. I tried to scavenge everything off the donor vehicle I thought I would need.
Old 05-05-2011, 09:10 AM
thepitshop's Avatar
thepitshop thepitshop is offline
thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.
Nice build!!! those factory ford diagrams are the best way to go if your using the stock harness,! i did the same thing for my `88 powertrain, removed all the looms and traced all the circuits, removed all the ones i didn`t need, mine is ready to pluck in but i want to finish body work first
Old 05-05-2011, 03:42 PM
gregstith's Avatar
Nice truck thepitshop,
Did you bag the front of your truck as well? I would love to slam my truck. It has a camaro front clip that was on it when I bought it. I really want to get it lower, but I don't want to spend a ton in the bag system. I'm trying to learn more about it.
Old 05-05-2011, 07:34 PM
mnicosia23's Avatar
mnicosia23 mnicosia23 is offline
mnicosia23 is starting off with a positive reputation.
nice progress! body work looks really good keep it up and keep us updated!
Old 05-05-2011, 09:42 PM
BACAGrizz's Avatar
BACAGrizz BACAGrizz is offline
BACAGrizz has a good reputation on FTE.BACAGrizz has a good reputation on FTE.
First chance I had to play the video. Sounds great. Keep up the good work. Keep on posting those pix too!
Old 05-05-2011, 09:57 PM
SunDown's Avatar
SunDown SunDown is offline
SunDown is starting off with a positive reputation.
Just brought home a 4.6 2v I pulled from a 97 lincoln town car.. I managed to get the engine, trans, computer and what I could get of the harness. These darn Haynes manuals arent worth a whole lot. I need to find a wiring schematic like you found!
Old 05-06-2011, 07:48 AM
thepitshop's Avatar
front and rear are bagged, bought individual bags from airbaggit.com and built my own brackets and mounting plates.
Old 05-06-2011, 09:31 AM
gregstith's Avatar
Thanks everyone.
Quote:
That's awesome! Do you have any pics of bagging the front? Did you get the compressor and fittings from airbaggit as well?
Old 05-06-2011, 01:01 PM
thepitshop's Avatar
there`s a few pictures scatered in my gallery but not mutch about the bagged front end, the above pic is the top bag mount i built, i first built and welded a bottom plate to cover the bottom a-arm, then positioned the bag and collapsed the suspension, i then measured the gap between the bag (collapsed) and top of the suspension mount, cut a piece of tubing 1/4 inch longer than measured ,drilled a hole in the bag mounting plate (center) the size of ready rod i used (don`t remember) welded the ready rod to the bag plate ,then welded the top bag plate to the tube, compressor controller and tank came used from e-bay, air ride technologies system
Old 05-06-2011, 09:02 PM
gregstith's Avatar
Thanks for the info. What size bags did you get?
Old 05-07-2011, 06:48 AM
While doing some reasearch on air bags I learned that the better ride comes from the bags with the biggest diameter you can fit. As I understand it the bigger bags allow less air pressure for the same height.
Don't forget to feed each bag from a separate source. Otherwise in turns it will transfer air pressure from the bag on the outside to the bag on the inside.
Good luck.
jim
  #28
Old 05-07-2011, 08:39 AM
gregstith's Avatar
When you say from a different source, does that mean different solenoid for each wheel?
I've been searching for a forum on airbag suspension setups and terminology and such. Haven't found a good one yet. Wish I could find one as informative as this site is
  #29
Old 05-07-2011, 03:30 PM
I am no expert but from what I understand that you need 4 valves for 4 bags. That way you don't get any cross feeding. If you pickup a mini truck mag it usually has a large technical section from air baggit. Of course they are trying to sell their product but there is a lot of good info such as air driers from the air compressor, use an aluminum tank as there will be no rust and stuff like that. I have also learned that there are such things as an air leak down valve that controls how fast the bag works going down. It appears there is a lot to it but it is also fairly easy to learn.
You also understand that you can make this as simple or as complicated as you want. You can put a simple schreader valve [like bicycle valve] on each line and fill separately upto a full on multiple control system. Your choice.
If you can do your truck, you can do this.
jim
  #30
Old 05-07-2011, 04:54 PM
gregstith's Avatar
Thanks Jim,
I've been reading on Airbaggit.com and layitlow.com. You're right, seems like it's a lot like other aspects of vehicles. You can have a simple farily cheap design or have the expensive designs with all the bling. I'm pretty simple so if/when the time comes to lower my truck that's the route I'll go.
Thanks again.
Considering a 1999 with 4.6 or 5.4 ? gman97005 1968-2013 Full Size Vans 9 01-13-2016 11:38 AM
A little Ford bashing from a Ford employee gregstith 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 05-04-2014 07:56 PM
The Journey - Junk to Jewel? 1948 F1 Body gregstith 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 06-14-2013 10:30 AM
To guys doing fuel tank relocation gregstith 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 10-04-2011 10:01 PM
Hello all, new to the site gregstith 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 01-03-2011 02:03 PM
Tags
1948, 1970s, 46, 49, accessories, diesel, engin, engine, ford, mod, modular, motor, motors, pickup, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
