49 truck with 4.6 modular motor-IT'S ALIVE!!! - Page 19 - Ford Truck Enthusiasts Forums
  #271
Old 03-07-2014, 09:42 PM
gregstith's Avatar
gregstith gregstith is offline
gregstith is gaining momentum as a positive member of FTE.gregstith is gaining momentum as a positive member of FTE.
Been doing a lot of small detail work on the bed along with grinding welds. Started working on relocating the filler neck on the gas tank today. Cut a c-notch in the frame. Hopefully will get it welded tomorrow along with this filler neck I made today.
  #272
Old 03-08-2014, 04:10 PM
gregstith's Avatar
Got the filler neck welded to tank and c-notch welded up.
  #273
Old 02-18-2015, 04:23 PM
c91x's Avatar
c91x c91x is offline
c91x has a great reputation on FTE.c91x has a great reputation on FTE.c91x has a great reputation on FTE.c91x has a great reputation on FTE.c91x has a great reputation on FTE.
Awesome work. Same drivetrain i'm using (picking up the donor this weekend).
What all did you snag from the donor
  #274
Old 02-19-2015, 01:18 AM
mustangmike6996's Avatar
mustangmike6996 mustangmike6996 is offline
mustangmike6996 has a good reputation on FTE.mustangmike6996 has a good reputation on FTE.
Obviously the Engine and trans.
ECM, Wiring harness, Dash wiring harness, instrument cluster, ignition switch and keys, dash harness, power steering hoses.
If you have free reign then grab all that you can. The worst case scenario is you end up with extra and throw some things away. If you can grab all of those electronics you will have an easier time installing it in your truck and removing what you dont need as opposed to trying to find a tiny part you missed.
  #275
Old 08-04-2015, 04:46 PM
c91x's Avatar
Any updates Greg ?
  #276
Old 08-07-2015, 11:46 PM
Philthy50 Philthy50 is offline
Philthy50 is starting off with a positive reputation.
What an incredible job. Just starting work on my 50. planning on installing a 4.6 from a CVPI.
  #277
Old 05-03-2016, 10:41 PM
steve2787 steve2787 is offline
steve2787 is starting off with a positive reputation.
4.6 engine install
i am starting a resto on a 49 f1. planning to go with the 4.6 with automatic. what wiring harness should i use for the computer hook up and what about compatability with guages and other electronics. also need suggestions on a donor front suspension and power steering set up
  #278
Old 05-04-2016, 09:58 AM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Use the original for motor & trans control. Contact Chuck! He'll clean up your harness for 1/2 the price of a new one.
Chuck's Roadster Electrics, (530) 477-7829 or mustang-medic@hotmail.com
For the rest of the truck use the original or one of the better aftermarket wiring kits.
Pics of new rear fenders f1 gregstith 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 09-22-2013 12:57 PM
Making a rollpan gregstith 1948 - 1956 F1, F100 & Larger F-Series Trucks 35 07-31-2013 07:39 PM
The Journey - Junk to Jewel? 1948 F1 Body gregstith 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 06-14-2013 11:30 AM
Is this rare? (Data Tag) gregstith 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 11-27-2012 09:27 AM
Hello all, new to the site gregstith 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 01-03-2011 03:03 PM
Tags
1948, 1970s, 46, 49, accessories, diesel, engin, engine, ford, mod, modular, motor, motors, pickup, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
