firewall crack in engine comparment - Ford Truck Enthusiasts Forums
Old 01-31-2011, 06:32 PM
cdat81986 cdat81986 is offline
cdat81986 is starting off with a positive reputation.
88 f250 5.0 4x4 5 speed
i noticed the plate in the engine compartment around the master cylinder seems to have detached from the firewall. the clutch pedal wont return to the top of its stroke. i checked the clutch rod and bushing both are still ok. when i press the clutch i can see the plate get pushed even further away from the firewall.
do these reinforcement kits correct the plate detachment in the engine compartment?
can i weld the plate back to the firewall??
someone who had dealt with this before please help!!!!
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old 01-31-2011, 06:38 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
This used to be a common problem, and Ford made a firewall repair kit for them, BUT-they're now discontinued from FoMoCo. Possibly available from an aftermarket source, or you may have to make something on your own.
Old 01-31-2011, 06:52 PM
ive done some research on the kits from ford but i can find any information on the big kit, just the small kit.
do these kits install from inside the cab or on the outside?
with the plate being detached in the engine compartment would the much cheaper small kit be enough to fix my problem or would it require the bigger kit??
Old 01-31-2011, 07:53 PM
F150xlt F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
Click on the link below which describes both the small plate and large plate repair.
F150 clutch master cylander braket seperation - FixYa
(To install the small reinforcement bracket). From inside the cab
you remove the two nuts holding the clutch master cylinder to the plate
that is pulling away from the firewall.
Install the bracket over the two studs of the clutch master cylinder and reinstall
the two nuts. The bracket clamps the under the hood plate the clutch master
cylinder is attached to, to the firewall.
This repair works as long as the firewall has no major cracks.
This is a picture of the small reinforcement bracket.
Old 01-31-2011, 08:43 PM
i think ill try to buy the small bracket and see where that takes me.
so the correct part number for the small bracket that is pictured in the last post is e3tz-7k509-a ?
Old 01-31-2011, 09:24 PM
The small bracket is $5.00 e8tz7k509a
The doubler kit is $170.00 e3tz7k509b
The repair kits are over twenty years old so Ford
may no longer sell them.
WTB - '57-'60 Clutch Master Cylinder Delete Plate oldbleu WTB - Parts & other 8 10-04-2016 05:25 PM
turn signal fuse keeps blowing cdat81986 1987 - 1996 F150 & Larger F-Series Trucks 7 02-18-2014 03:46 PM
ZF5 Swap Master cylinder question: MPoulson Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 09-18-2013 09:35 AM
HOWTO - Firewall Flex/Crack Repair ctubutis '80-'86 HOWTO's 0 02-08-2011 09:51 PM
Dana 21 Shift Knob Circle5 1967 - 1972 F-100 & Larger F-Series Trucks 7 04-12-2010 10:14 PM
Tags
crack, cracking, cracks, engine, f150, fire, firewall, ford, issues, kit, reinforcement, repair, series, straight6, trucks, wall, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
