Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
93 Lightning EEC Failure?
Old 01-31-2011, 04:39 PM
WutBrakes351w's Avatar
WutBrakes351w
WutBrakes351w is offline
Hi, I'm hew here but love the site. Everyone has been extremely helpful. Here's my question....The EEC fried in my 93 Lightning 5.8 351w e4od, should I replace it with the same exzact one? Should I go with aftermarket? I have a vortech geared supercharger w/ the whole set up on it, can the stock eec be programmed for mods?
Old 02-01-2011, 05:42 PM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I think your best bet is just getting an OEM one. Make sure the codes are all the same. There are different codes for different transmissions as well. Orielly or Advance may be able to get one.
What does Vortech recommend?
Just wondering, how did it get fried?
Old 02-02-2011, 08:25 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Need to know a little more about the modifications; are you running an FMU with a timing retard or does it have a chip in the J3 port of the ECU?
Old 02-03-2011, 11:36 AM
WutBrakes351w
Yes I have the FMU setup. I'm having trouble finding the part now
Old 02-04-2011, 07:57 AM
Blurry94's Avatar
Blurry94
Blurry94 is offline
You can try looking on nloc.net, in the classifieds for a used ECU. You'll at least want to try and get a factory type ECU like C3P1, C3P2, C3P3 or ICY1 because the transmission settings are a little more aggressive, and the timing tables are different between a GEN 1 and F-150. Otherwise, any 5.8/E4OD (pre OBD-2) ECU from that era would work
Is the motor running rough, will it even start?
Old 02-04-2011, 04:37 PM
WutBrakes351w
It starts and runs but really rough, I have the ecm out of it now and I'm tryin to find a replacement for that exact model
Old 02-04-2011, 06:58 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
If you're running a boost/timing retard, try bypassing it first. It is not uncommon for one to go bad, or have wiring problems, and cause the motor to run bad.
RIKIL
04-19-2023 09:15 PM
badford64
20
11-21-2013 05:21 PM
WutBrakes351w
02-06-2011 05:17 PM
WutBrakes351w
02-03-2011 01:31 PM
jeff moon
01-31-2003 04:00 PM
Quick Reply: 93 Lightning EEC Failure?
