Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 01-31-2011, 04:39 PM
WutBrakes351w's Avatar
WutBrakes351w WutBrakes351w is offline
1993 Ford F-150
WutBrakes351w is starting off with a positive reputation.
93 Lightning EEC Failure?
Hi, I'm hew here but love the site. Everyone has been extremely helpful. Here's my question....The EEC fried in my 93 Lightning 5.8 351w e4od, should I replace it with the same exzact one? Should I go with aftermarket? I have a vortech geared supercharger w/ the whole set up on it, can the stock eec be programmed for mods?
  #2 (permalink)
Old 02-01-2011, 05:42 PM
TexasGuy001's Avatar
TexasGuy001 TexasGuy001 is offline
Garage is empty, add now
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I think your best bet is just getting an OEM one. Make sure the codes are all the same. There are different codes for different transmissions as well. Orielly or Advance may be able to get one.
What does Vortech recommend?
Just wondering, how did it get fried?
__________________
1995 F-150 XLT 2WD 5.0 4R70W 3.55 LS (awaiting 5.8 swap)
1965 Mustang 302 T5
PICTURES AND INFO IN GALLERY
http://www.youtube.com/watch?v=KF7soIRbh9M
Texas Chapter
Fix It Up Don't %$@# It Up
  #3 (permalink)
Old 02-02-2011, 08:25 PM
Blurry94's Avatar
Blurry94 Blurry94 is online now
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Need to know a little more about the modifications; are you running an FMU with a timing retard or does it have a chip in the J3 port of the ECU?
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #4 (permalink)
Old 02-03-2011, 11:36 AM
1993 Ford F-150
Yes I have the FMU setup. I'm having trouble finding the part now
  #5 (permalink)
Old 02-04-2011, 07:57 AM
Blurry94's Avatar
1994 Ford Lightning
You can try looking on nloc.net, in the classifieds for a used ECU. You'll at least want to try and get a factory type ECU like C3P1, C3P2, C3P3 or ICY1 because the transmission settings are a little more aggressive, and the timing tables are different between a GEN 1 and F-150. Otherwise, any 5.8/E4OD (pre OBD-2) ECU from that era would work
Is the motor running rough, will it even start?
__________________
Matt C.
  #6 (permalink)
Old 02-04-2011, 04:37 PM
1993 Ford F-150
It starts and runs but really rough, I have the ecm out of it now and I'm tryin to find a replacement for that exact model
  #7 (permalink)
Old 02-04-2011, 06:58 PM
Blurry94's Avatar
1994 Ford Lightning
If you're running a boost/timing retard, try bypassing it first. It is not uncommon for one to go bad, or have wiring problems, and cause the motor to run bad.
__________________
Matt C.
Tags
150, 93, c3p1, c3p2, ecm, eec, failure, fix, ford, fox, headers, lightning, locate, mustang, pickrel, replace, timing, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
