Max tow? - Ford Truck Enthusiasts Forums
Max tow?
Old 01-31-2011, 01:13 PM
drh1175 drh1175 is offline
drh1175 is starting off with a positive reputation.
Max tow?
The Max tow gives you the Tow mirrors, 3.73 axle, Upsized Radiator, Transmission Cooler and Hitch. What kinda hitch does it come with it must be rated for 11,300lb is it a 12k hitch? What else do you get in the max tow? I have heard a stronger Steering Ratio Is there something else I am missing?
Old 01-31-2011, 07:49 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
I think you also get upgraded rear springs with the max-tow package.
Old 01-31-2011, 08:45 PM
skidooman's Avatar
skidooman skidooman is offline
skidooman is gaining momentum as a positive member of FTE.skidooman is gaining momentum as a positive member of FTE.
I thought the tow mirrors were a seperate option. I had to pay 360 extra for the tow mirrors over the max trailer tow package.
Old 01-31-2011, 10:59 PM
bigal1234 bigal1234 is offline
bigal1234 is starting off with a positive reputation.
I believe that you also get a heavy duty rear bumper as well as the above.
Max tow package is for trailers over 5000lb. I also had to include trailer tow mirrors as a seperate item.(360.00). For some reason on my order the max tow package was $1000.00 and then $500.00 credit. So only $500.00.
Al
Old 01-31-2011, 11:56 PM
excoelis's Avatar
excoelis excoelis is offline
excoelis is starting off with a positive reputation.
Tow mirrors are an option, mine has Max tow with larger radiator and oil cooler, trailer brake control, 3.73 rear axle and all the goodies but the mirrors are just regular mirrors.
Old 02-01-2011, 12:06 AM
Power Kid Power Kid is offline
Power Kid is starting off with a positive reputation.
In Canada the big mirrors are optional, I think they are std in us with max tow.
Old 02-01-2011, 12:18 AM
blueovelboy's Avatar
blueovelboy blueovelboy is offline
blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.
i have searched this out. all max tow gives you is the
A) upgraded trans cooler
B) 7700 lbs leaf springs
C) 20:1 steering
D) 3.73 gearing
now if you want true max tow get a lariat or platinum and i think king ranch. thay will come with thees extras up to 2010. i cant say any thing about 2011's as i know not!
the trailer brake controller is an extra on every thing south of the lariat.
the tow mirrors are also an extra on every thing south of the lariat.
the receiver and the 7 pin / 4 pin plugs come with a regular tow package or max tow!
this was told to me buy one of the head mechanic at local ford dealer. (mission valley ford trucks)
this is why some of us had to add the mirrors or TBC modules.
i dont know if the max tow receiver is rated for 12,000 lbs. but i guess it has to or thay could not clam 11300 lbs. but i also thought 12,000 lbs receivers had a 2.5" hole in them? i dont know that much about receivers so?
Old 02-01-2011, 07:14 AM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
Out of curiosity, what is the spring code for the heavier springs on the max tow?
Old 02-01-2011, 11:39 AM
Are springs the same as what is on the heavy duty payload package. I am ordering the super crew so hd payload is not. Available. I am assuming so since the GCWR is the same on either truck.
Pp
Old 02-01-2011, 11:54 AM
Deluxe05's Avatar
Deluxe05 Deluxe05 is offline
Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.
In an attempt to dispel some misinformation...
There are actually three separate Max Trailer Tow Packages per the 2011 F-150 Order Guide (published 09/03/10). However, the differences between them are pretty much limited to the mirrors themselves. (Package 60C is only available on Lariat, King Ranch, and Platinum, and those already have the SelectShift transmission.)
This Order Guide may be slanted towards the US markets. Hence, some differences may be seen in other markets.
Quote:
MAX TRAILER TOW PACKAGE – MANUAL MIRROR (60M)
Availability:
  • Optional on XL Regular and SuperCab
Not Available with:
  • 126" wheelbase
  • Power Equipment Group (85A)
  • Max Trailer Tow Package (60P)
Requires:
  • 3.5L EcoBoost™ Engine (99T)
  • 3.73 LS rear-axle ratio
  • Heavy-Duty Payload Pkg. (627)
  • XL requires Fog Lamps (595) with XL Décor Group (86D)
Includes:
  • Upgraded rear bumper
  • Class IV trailer hitch receiver
  • 7-pin wiring harness
  • Upgraded radiator
  • Auxiliary transmission oil cooler
  • Trailer Brake Control
  • SelectShift Transmission
  • Side mirrors, black manual telescoping trailer tow w/manual glass
MAX TRAILER TOW PACKAGE – POWER MIRROR (60P)
Availability:
  • Optional on XL Regular and SuperCab, XLT and FX2/FX4
Not Available with:
  • 126" wheelbase
  • Max Trailer Tow Package (60M)
  • XLT SuperCab 145" wheelbase with P235/75R17 BSW A/T (T7B), L245/75R17E BSW A/T (T7E) or P255/65R17 OWL A/S (T73)
  • XLT SuperCrew with P255/65R17 OWL A/S (T73) or L245/75R17E BSW A/T (T7E)
Requires:
  • 3.73 LS rear-axle ratio (XL, XLT and FX2)
  • 3.73 electronic-locking differential axle (XLT w/Off-Road Pkg. – 55A and FX4)
  • XL requires Fog Lamps (595), XL Décor Group (86D) and Power Equipment Group (85A)
  • XL and XLT Regular Cab requires Heavy-Duty Payload Pkg. (627)
Includes:
  • Upgraded radiator
  • Side Mirrors, black manual telescoping trailer tow w/power glass (includes heat, turn signal & puddle lamps)
  • Memory feature included on side mirrors when order with FX Luxury Package (55F)
MAX TRAILER TOW PACKAGE – POWER, CHROME MIRROR (60C)
Availability:
  • Optional on Lariat, King Ranch® and Platinum
Requires:
  • 3.5L EcoBoost™ Engine (99T) or 6.2L V8 (996)
  • 6.2L V8 on Lariat and Platinum also requires SuperCrew 145" WB
  • 3.73 electronic-locking differential axle (Lariat or King Ranch® w/Off-Road Pkg. – 55A)
Includes:
  • Upgraded radiator
  • Side Mirrors, Manual Telescoping Trailer Tow w/Power Glass (includes heat, memory, turn signal & puddle lamps & Chrome Skull Caps)
Incidentally, a class IV trailer hitch is rated for 12,000lbs with a 1,200lbs tongue weight.
Old 02-01-2011, 12:17 PM
Deluxe05's Avatar
The 20:1 steering piece was puzzling me, and I went digging around. I can find references in the 2009 model year F-150 sales brochure & Order Guide that this was a standard component of the Max Trailer Towing Package. However, I have not seen that in any Ford literature before or since, and I went through sales brochures & Order Guides ranging from 2007 through 2011.
Maybe that steering change was dropped due to negative feedback? Or, maybe it was just dropped from the literature? It is hard to say at this point.
Old 02-01-2011, 12:28 PM
Oh and they have the electronic power steering. For 2011 Maybe that is why the 20:1 ratio doesn't show up
Old 02-01-2011, 04:41 PM
THANKS DELUXE05 i wonder where did you find this info? i have been thru all sorts of brochures / pamphlets & shop service manules.
now is it true that the max tow with the 3.73 gears allso comes from factory with a 7 lug or was that just 04-08 7700 lbs payload?
Old 02-01-2011, 06:55 PM
Mine is coming with 7 lug wheels(17inch).
Al
Old 02-02-2011, 04:18 AM
svt2205 svt2205 is offline
svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.
Download a copy of the order guide, it will fill in lots of blanks that other Ford documents don't offer up.
http://www.profleetsales.com/pdf_fil...er%20Guide.pdf
You may need a weight distribution hitch (WDH) Billyclub 2009 - 2014 F150 52 10-23-2015 08:50 AM
MAX TOWING Michel153 1987 - 1996 F150 & Larger F-Series Trucks 2 10-09-2014 08:41 PM
For those who tow trailers with their Ranger - A Question... Furyus1 Ranger & B-Series 41 04-11-2013 08:25 AM
Max Tongue Weight on Exdy cecilt Expedition & Navigator 1 12-10-2009 05:01 PM
maximum trailer towing tbejr Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 6 03-06-2001 11:39 AM
Tags
0408, 2011, 50, black, bumper, f150, fx4, lariat, max, navigation, package, rear, sale, tow, upgraded, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
