Tailgate camera
Old 01-31-2011, 10:27 AM
glenndibler's Avatar
glenndibler
glenndibler is offline
Tailgate camera
Does anyone know if there is a camera that will plug into the tailgate camera harness when the tailgate is off. I want to install a camera in
the back of my camper and plug it into the camera harness.
Any ideas on a solution.
Old 01-31-2011, 01:57 PM
Sportscraft's Avatar
Sportscraft
Sportscraft is offline
Ford sells some of its connectors in order to repair damaged ends. If you can find the right connector and sort out which wire is which, you might be able splice an aftermarket camera in.
Old 01-31-2011, 03:18 PM
rdenis's Avatar
rdenis
rdenis is offline
I don't know if the connector is available but here is all the info you need to tap into the existing camera circuit. Also here is the connector and part number in case it is available:
Rear Camera Circuit:
Connector C497:
Old 01-31-2011, 07:22 PM
lexustbs's Avatar
lexustbs
lexustbs is offline
Connector C497:
Is that connector in the tailgate, even if you do not have the factory camera? I want to add a camera to my NAV, and I like the factory location, but doubt its likely to work there.
Old 01-31-2011, 09:44 PM
rdenis's Avatar
rdenis
rdenis is offline
No it's not in the tailgate - it is under the truck between the rear bumper and the spare tire, just right of center.
Old 02-01-2011, 08:02 PM
porthole's Avatar
porthole
porthole is offline
Right next to the bright orange cap for when you remove the tailgate.
saskowner
2017+ Super Duty
26
04-06-2020 08:24 PM
RUNVS
01-13-2020 11:14 PM
Criegg
1999 to 2016 Super Duty
06-05-2019 07:16 PM
AJCASSARO
06-07-2017 11:43 AM
tjc transport
06-02-2017 04:40 AM
Quick Reply: Tailgate camera
