Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 01-31-2011, 06:31 AM
nycsteve nycsteve is offline
Garage is empty, add now
nycsteve is starting off with a positive reputation.
Oil Change choices
So the manual gives a choice of full synthetic,synthetic blend,premum synthetic blend,and regular oil. Since I will be on the heavy duty maintainance shedual with a change evey 5000 miles I was thinking either the regular oil or the synth blend. I was told full synth will increase gas milage. True? Any advantage of premium synth blend over reg synth blend? Any issues using Mobil 1 synth?
In the past I never used synth, always on schedual with regular oil changes and had good results.
  #2 (permalink)
Old 01-31-2011, 01:31 PM
jlalanas's Avatar
jlalanas jlalanas is offline
jlalanas is starting off with a positive reputation.
FWIW - I plan on going with the synthetic blend at 5k increments. I think my driving would fall more in the regular schedule, but rather be safe than sorry. Are you planning on DIY or having the dealer do it? If the later, any idea what the cost difference is between the oil grades?
__________________
John
'12 F350 Lariat 6.7 CC, Sterling Grey
3.55, Nitto Trails 295/65/20, S&B Intake, Access Bed Cover, Weathertech floor liners, Carli 2.5 Pintop, Bil 7100Stabilizer, Linex
2011 Ducati Multistrada, 2011 KTM 250xc
  #3 (permalink)
Old 01-31-2011, 02:16 PM
RLBrown502 RLBrown502 is offline
RLBrown502 is starting off with a positive reputation.
nycsteve - I have always used full synthetics in all my vehicles and race bikes (I raced GNCC and hairscrambles). I cannot recall the exact difference between the reg. and premium snth blends, but with some research I am sure you find the difference between additives, and volume contained in each.
IMO - the synth blends are a waste of money but some people just can't bring themselves to spend the extra money on a full synthetic. I never had good success with the blends that I tested in my bikes. However, I have had great results with Mobile 1 full synth with a little bit of Lucas oil stabilizer added. I cracked a case during one race and I managed to finish with no oil left in the crankcase while using this combo...and yes there was some damage but nothing seized. I have used this combo successfully in my race bikes for the last 5 years and it has showed the least breakdown of all the oils I tested. The only other oil I would recommend is AMSOIL but it is a bit pricey.
I am sure you have heard it before....but oil is cheap insurance against failure. After my first oil change, I plan on using the Mobile 1/Lucas combo for the life of the vehicle.
Regards,
Rick
  #4 (permalink)
Old 01-31-2011, 08:13 PM
Radioactive 4x4's Avatar
Radioactive 4x4 Radioactive 4x4 is offline
Radioactive 4x4 is starting off with a positive reputation.
I would have to agree on the full synthetic with the Lucas additive. I justify the price difference by doing it myself instead of $35 at a pull-in place. Just a word of advice tho, I was at my dealer last Weds checking on the body module that was suppose to catch fire or some crap and if there was any TSB's on "ticking" 6.2L ( yes, mine has started to do it at 850 miles) and I asked about changing oil and doing it myself. She said just to be sure to keep reciepts of oil bought and GET THIS you HAVE to use a Ford motorcraft filter only! She said Ford voided a warranty on a motor because there was an aftermarket oil filter on it. F'in CRAZY. I'd rather use a Bladwin filter over a FMC filter any day!
__________________
White tri-coat metallic 2011 F-250 Lariat CC 4x4 Off-Road, 6.2L, 4.30 gears, SB, 275-70-18 Michelin LTX AT2
HAULIN A#% AND SUCKING GAS
  #5 (permalink)
Old 02-01-2011, 07:57 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Everytime I read about someone using Lucus additives, I throw up in my mouth just a little bit.
I'm not sure if it's the same stuff, but my brother-in-law used the oil "stabilizer" or whatever it's called, and he lost TWO motors within a few months.
If the vehicle is under warranty, WHY SCREW with additives?
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see. ®
  #6 (permalink)
Old 02-02-2011, 11:51 AM
Hey, what can I say other than anything can happen, additives or not. Still, I can understand where you are coming from as i had similar experience when I lost the bottom end in a perfectly running 355 chevy 3 weeks after I started using the STP suppliment. I chose to use the additive after having a conversation with an old time gear head who swore by the stuff and had used it in everything he ever built. Nevertheless, I cringe everytime someone mentions an STP product.
Based on my experience, I have had a good track record using the Lucas product in several of my vehicles, and race bikes, and know of several other individuals who also use the product in some high end motors. However, I am sure any additive (even Lucas), can damage a motor if certain factors are provided.
My reasoning for using additives under warranty is because I am thinking of the long term wear on the motor after the warranty is up.
All it comes down to is personal experiences. If I had lost two motors due to a specific additive or fluid, then I would defnitely be voicing a strong opinion against its use.
BTW, what was the mileage and final analysis on your Brother-in-law's motors? Reason I am asking is because I have always had concerns with the over use of an additive, and also its beginning use in a higher mileage motor.
Thanks,
Rick
  #7 (permalink)
Old 02-02-2011, 01:01 PM
Krewat's Avatar
Quote:
My concern is what Ford would think about that "additive" and if they would honor the warranty with it. Something tells me they won't.
Both motors suffered from catastrophic oil pressure loss. One, an I6-300 with around 80K miles spun a MAIN bearing. The other, a 351W with very high miles (>150K) lived, but never ever stopped ticking/knocking afterwards and went to the scrap yard before it blew up on it's own. He was religious about oil changes on the I6-300, so I can't imagine anything was building up inside the engine for the additive to break loose and cause problems.
But either way, they both seemed to have oil pump bypass valve problems within a few weeks, NOT RIGHT AWAY.
What I'm really concerned about is WARRANTY. Unless Ford says it's OK in the owner's manual, STAY AWAY. Any decent oil will be "stable" enough between oil changes.
__________________
  #8 (permalink)
Old 02-02-2011, 04:54 PM
Ford Big Rig's Avatar
Ford Big Rig Ford Big Rig is offline
Ford Big Rig is starting off with a positive reputation.
I always use Mobil 1, dont think I will go full synthetic till warranty goes out and use the maintenance schedule every 7500 miles..but I'm not towing anything that heavy.
__________________
2011 F250 6.2 Gas 4x4 Auto 3.73 Marines 73-76 LVTP7
  #9 (permalink)
Old 02-02-2011, 08:54 PM
Thenewboss's Avatar
Thenewboss Thenewboss is offline
2011 Ford F-250
Thenewboss is starting off with a positive reputation.
Motorcraft semi-synthetic 5W20, Motorcraft filter, 5000 miles. As far as factory spec oils go, the Motorcraft gets great reviews, as well as good oil analysis. In my opinion there's no need to spend any more on so called boutique type oils.
  #10 (permalink)
Old 02-03-2011, 03:16 AM
ROTTEKATZ ROTTEKATZ is offline
2011 Dodge Ram 1500
My Garage
ROTTEKATZ is starting off with a positive reputation.
Smile
Quote:
TSB 10 25 07 addresses the rocker arm ticking. At least the dealer stocks the parts now.
  #11 (permalink)
Old 02-03-2011, 05:31 PM
Scrming's Avatar
Scrming Scrming is offline
2011 Ford F-250
Scrming is starting off with a positive reputation.
Hmmm... this is a clear violation of Magnuson-Moss Warranty Act!
From the K&N site:
"Under this federal statute, a manufacturer, who issues a warranty on your motor vehicle, is prohibited from requiring you to use a particular brand of air filter, oil filter, or other service or maintenance item, unless such item is provided, free of charge, under your warranty or unless the Federal Trade Commission (FTC) waives this prohibition against the manufacturer. K&N is unaware of any exemption or waiver granted by the FTC to any motor vehicle manufacturer, which pertains to air filters or oil filters."
link:
Letter from K&N CEO - Automotive Dealers Voiding a Warranty due to a K&N Replacement Filter
Also check out:
SEMA SAN - SEMA ACTION NETWORK
  #12 (permalink)
Old 02-03-2011, 07:35 PM
Quote:
From the K&N site:
link:
Also check out:
Good to know! Thanks Scrming
__________________
  #13 (permalink)
Old 02-03-2011, 09:05 PM
Krewat - thanks for sharing the examples. I honestly have no idea how the Lucas could have caused those failures but I am sure it did play a part given the mileage on both motors. Whenever I switched to full synthetic or an additive with high friction modifiers in a high mileage vehicle, I usually ended up with leaking seals, spun bearings, or some other odd failure. Thus, the reason why I would start using the full synthetics after break-in, rather than later with higher mileage.
Scrming - Interesting find.
  #14 (permalink)
Old 02-04-2011, 07:00 AM
Krewat's Avatar
Yeah, I have no idea why either, but the fact that they both did it within a few weeks of using the "stabilizer", meanwhile the guy had been doing all his own oil changes for years with the exact same oil, well, extremely fishy to me.
In my opinion, if you need a "stabilizer" I would start changing the oil more frequently then once a year
__________________
  #15 (permalink)
Old 02-04-2011, 09:09 AM
Dang, your suppose to change it more frequently than once a year now? CRAP I didn't get the memo
__________________
Tags
1972, 2006, 500, 62, capacity, chages, change, duty, filteroil, ford, meter, mileage, oil, set, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
