Go Back   Ford Truck Enthusiasts Forums > Bronco > 1966 - 1977 Early Broncos
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1966 - 1977 Early Broncos SPONSORED BY:
  #1 (permalink)
Old 01-30-2011, 09:46 PM
mauicruza's Avatar
mauicruza mauicruza is offline
Garage is empty, add now
mauicruza is starting off with a positive reputation.
efi to C4 kickdown cable question
Question for you guys that converted over to efi using the stock C4 auto trans mated to the 5.0 efi T/body. Lokar makes a nice kickdown or tv cable for this, I believe the pt# is 20c4ht. Here's my question. My throttle body arm travels 2 3/4" from idle to wot but my c4 kickdown arm only travels 11/16". How do I match the correct geometry. The way I see it is I'll bottom out on the trans arm only at part throttle. Did you guys lengthen the trans kickdown arm so the travel is equal to the Tb? The pics of the lokar cable on the summit site doesn't show anything as far as a modified bracket. Thanks for any replies.
  #2 (permalink)
Old 01-31-2011, 10:50 AM
chrlsful's Avatar
chrlsful chrlsful is offline
2001 Ford Focus
My Garage
chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.
If there's not enuff familure here w/that Q classisbronco dot com will surely have a tech write up article archived for use or doz of guys w/ (some right too!) answers. U may wanna pin yer ears back 1st, tho - some pretty big egos.
Good Luck, keep in touch, wont B long some 1 will b along w/more help n me ;- }
__________________
Chad
'70 LUEB 1/2 cab, '77 frame ie: D44, BB 9" w/411, "T" D20/PTO, 250cid mid-swap, Carter RBS, 2"SL, 4 discs, 3.03/3 sp Hurst. Seeking: 240/300 1v low rise Carb., hydraulic Gear Motor for koenig or zf ptos, zf E-Brake, 3'X10" auger.
chrlsful@aol.com, 413 259-1749
  #3 (permalink)
Old 02-01-2011, 12:01 AM
mauicruza's Avatar
Ok thanks. I think I can redrilll the t/b throttle bracket so the cable will attach closer to the center where there is less travel. This will decrease the movement of the cable from 2 3/4" down to maybe 1 1/2". I then could try and modify the stock kickdown arm so it will be longer and have equal travel from idle to wot. The cable will now have to attach to the back of the trans selector lever rather than the front. I'll let you know how it turns out.
  #4 (permalink)
Old 02-01-2011, 10:05 AM
chrlsful's Avatar
2001 Ford Focus
My Garage
may B even yer own bracket outta angle stock, seen that done. not pretty but wrks.
yeah, keep postin, I'm surprised no 1 has come by
BTW: here's (a bronco w/modern engine) an FTE member on the Islands: Fungus232. Haven't talked to him since aug but know he has a bronk. REAL nice fella, not sure which island. Could B a good referral 4 ya!
__________________
Chad
Tags
50, arm, block, bronco, buy, c4, cable, control, efi, ford, hurst, kickdown, lever, trans, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
