Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- How to Refill Windshield Wiper Fluid
Step by step instructions for do-it-yourself repairs
Rear window washer fluid fill?
I've honestly looked thru my owner's manual several times.
Why is it I see that I have a rear window spray nozzle, but I don't see anywhere in back to fill up for using it? Is it supposed to flow all the way from the front to the back to work? If so, does ANYONE'S actually work?
Especially with winter here, I've kept my washer fluid reservior filled as much as possible, but in the 2 years I've owned it, I've never gotten anything out of my rear sprayer.
Stewart
It is a single reservoir system. It only has one pump. The pump reverses direction depening on the signal. One signal comes off a relay positive the other negative. The line for the back runs in through the fire wall by the passenger kick panel. (by the passengers right foot) There is a splice there. it then routes through the kick plates ( the plastic strips you step on when you get in)
I would find the splice I mentioned above, pull it apart and operate the rear washer. If fluid is coming out there, work your way back. Or you may want to pull the hose off at the rear wiper and see what you get. The orafice may be clogged.
Mine has always worked - with the exception of that splice coming apart.
I think the only other splice that gives issues is inside the hatch.
The following users liked this post:
Hi I just came across this thread and if you're still having the issue I wanted to add my input. I know its an old thread. Sorry to bother.
I had the same issue with mine (02 Explorer) cause my back window would get so dirty and washer fluid never dispensed back there. I cant imagine it'd be much different on the excursion since all that area looks similar to my 98 Expedition too. Then I finally went after it one day and started tracing the rear wash line right into the interior of the passenger wheel well. Had it all torn out trying to find the line.
Don't sweat, it turns out that right behind the coolant reservoir fill cap under the hood there's something like a black box, maybe a vent or fuse box? Well right underneath the box at hands reach was a rubber connector linking the one hose to another. Like to extend it. It was disconnected and I just plugged it back into the splitter now it works great everytime. Just don't know how it came off. I wouldn't mess with the wheel well though it was such a pain and I wasn't able to get back on the way it was. I have somewhat loose rocker panel corner now. Hope this helps!
Reps to ya.
Stewart
thought id bump this one a lil. was just repairing my rear wiper motor and found that the washer didnt work. so i held it down for about 3 seconds.... bad idea lol. the line was broke in the rear above the rear lights. it started raining in my truck. i would have to remove headliner to fix it, so thats not gonna happen.
rear wiper DOES work now tho lol
