You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Some folks have found that the hose will pop off at different locations.
Operate it ansd see if it is spraying fluid any7where inside or outside under the truck
Just finished repairing the leak in the washer fluid supply line on my Ford excursion. The syptoms were a constant dripping of the washer fluid around the back of the wheel and passenger door.
My leak was due to the line seperating at the firewall junction. All I had to do was pull the floor moulding on the pass. side door frame. Next pulled out the plastic quarter panel , then pulled back the carpet and floor liner and voila there it was. Simply shoved the tubing back into the connector and everything now works, Thanks again for those who post their experiences.
My break was in the passenger side kick panel where it goes through the fire wall. I hooked it back up and wrapped it in electrical tape.
When the season change from summer to winter (no fall in Canada lol) I found it frozen and when I went to blast it out after a trip to Walmart it rained all over are groceries from the back connection in the roof on the passenger side of the roof lite. Since its not raining washer fluid in your rear cargo area i would start with the passenger side fire wall under the carpet right under the glove box.
__________________
2002 Excursion Limited 4X4 7.3 PSD, Stock for now.
lol, it's real easy to get to with the Ex completely stripped down to the bare chassis!
My best suggestion would be to try taking the fender liner out, which would mean taking off all the stuff attached to it. But I think that would give you easiest access.
__________________
Jon
2005 Excursion Limited 4x4 V10, C1, TK/NH, 3/17/05, RedHead, Blackwood wheel, Rancho 9000XL, Air Lift, 61k
2002 Excursion Limited 4x4 PSD, 3/5/02, 150k, for parts & diesel swap
2007 Sunline Solaris T-286SR travel trailer, 3/8/06, 6691.8
