1 ton axles - Ford Truck Enthusiasts Forums
1 ton axles
Old 01-30-2011, 10:26 PM
pintoches's Avatar
pintoches pintoches is offline
pintoches has a good reputation on FTE.pintoches has a good reputation on FTE.
1 ton axles
Are the 76-77 1 ton axles a good choice? found good deal on whole truck?
Old 01-30-2011, 10:45 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
low pinion closed knuckle drum brakes and a 16sp D60 rear...
and btw, there were no 76-77 "1 ton" 4wd trucks.
Old 01-30-2011, 10:50 PM
pintoches's Avatar
Ok? It was open knuckle I looked! It had the larger hubs so I thought it was 1 ton. I have only sean large hubs on D60s
could it be a D60 under a 3/4 ton?
Old 01-30-2011, 10:56 PM
Yes thats possible. Any pics? Do you know if its a 76 or 77? Possibly 77.5?
Im not sure on all the specs for the 73-77 8lug D44s. I know "most" were closed knuckle, low pinion and drum brakes. The later 77 stuff started getting open knuckle and disk brakes. Big hub 44s were certainly very common though
Old 01-30-2011, 10:59 PM
pintoches's Avatar
only pics I have are from a old cell phone
Old 01-30-2011, 11:04 PM
eeeeh, cant tell much from the little pics.
very hard to tell but it looks like a 77 based on the emblem placement on the cowl rather than the fender though.
Old 01-30-2011, 11:22 PM
pintoches's Avatar
Ok it was leaf spring and had a power steering ram, if this helps
this is not the truck, but what I could see of the looking hubs they looked like this!
(my buddy's Jeep)
Old 01-31-2011, 03:26 AM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
i don't know a whole lot about highboys, but from the pic it looks to be sitting a little low to be one, so i would guess 77.5 or newer (so called "lowboy")without seeing it up close and/or personal, but buy hearing you say it had a steering ram i think 77 and older actual highboy with manual steering and an assist ram.
if the truck is close go take a socket set and tell us what size the diff cover bolts are and look at the front driveshaft. high pinion and low pinion placement are very easy to tell the difference on if you aren"t retarded. does the d-shaft enter above or below the center????
Old 01-31-2011, 07:42 AM
Here are some D44 big hub pics
Also check out Mr Ns website
http://77cj.littlekeylime.com/Dana44_3.htm
Otherwise the best thing to do would be take some good pics and we can tell you more about what youre buying.
Anybody have one? tinman52 1947 and Older Ford Trucks 2 08-03-2015 12:11 AM
parting out 1975 ranger 1/2 ton full time 4 wheel 360/390 motor sawmaned Ford Truck Parts for Sale 6 08-01-2015 09:02 PM
1/2 ton to 3/4 ton stromburg 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-17-2012 11:33 AM
Wanted: 39-47 1 ton: complete rear axle timdp 1947 and Older Ford Trucks 12 03-16-2011 01:00 PM
1/2 ton dana 44 to 3/4 ton dana 44 parts interchange??? scottf250us Offroad & 4x4 10 07-15-2009 09:09 PM
Tags
1978, 1986, 1ton, 77, axels, axles, f150, f350, fl, ford, forsale, highboy, ranger, sale, ton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
