Transmssion lines and cooler installation - Ford Truck Enthusiasts Forums
Old 01-30-2011, 08:18 PM
mirage5058 mirage5058 is offline
mirage5058 is starting off with a positive reputation.
Hello i just bought a 94 ford f250 7.3 idi there are no transmssion lines on it the guy i purchased it from was going to replace them and never did,also i want to install a trans cooler on it,im not sure of the correct way to install the lines and cooler.Could someone tell me how the lines hook up from tranny to radiator and which line you splice into for the cooler,the truck came with new cooler that was never installed either but there are no directions with it i just want to make sure i hook tranny lines to the correct places at bottom of radiator and cooler.Does the rear trans line hook up to right side of radiator on bottom (pass side)and front trans line to left side of radiator on botton (drivers side)and cooler is spliced into the line that comes from rear of tranny or line from front of tranny,thanks in advance for any help
Old 01-30-2011, 09:48 PM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
check 1980-1996 Ford Truck 1980-1996 Ford Bronco - LMC Truck Featured Products for the lines, its a e4od tranny. you want to run the pressure line into the radiator, the return line out of the radiator, cut it and put a 90 degree downward bend in it, run rubber hose from it to the aftermarket cooler, then the rubber line from the cooler to the return line that you cut. not sure what one goes where as far as left and right, im sure someone will jump in on that for you/
Old 01-30-2011, 09:51 PM
87crewdually's Avatar
87crewdually 87crewdually is online now
87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all
The line at the rear of the trans is the return from the cooler.
I run the lines according to manufacturers directions: Coming fron the trans, Front trans line to the radiator cooler, then back out of the radiator cooler to the auxillary cooler, finally out of the aux cooler back to the rear line on the transmission.
see here : Transmission Cooler Diagram Photo 3
Old 01-30-2011, 10:51 PM
My transmssion lines on tranny are not above one another like its shown in your diagram my trans has a line in the front and one in the very back of the tranny,I appreciate the help do you have a diagram thats shows the style tranny i have which is a e4od
Old 01-30-2011, 11:18 PM
Quote:
It's a generic diagrahm. I explained in the post, the FRONT line is OUT and the REAR line is the RETURN.
I hope this clears it up.
Old 01-30-2011, 11:47 PM
Sorry my mistake trying to do three things at once
Old 01-31-2011, 01:03 PM
eatont9999's Avatar
eatont9999 eatont9999 is offline
eatont9999 is starting off with a positive reputation.
I see, so you don't bypass the stock cooler, you just loop through it. What kind of hose should be used to do this? Will fuel line work? What size is the hose?
Old 01-31-2011, 01:08 PM
Quote:
Fuel line isn't rated for the temps and pressure. Use transmission hose. Depending on your lines they are either 5/16" or 3/8", 3/8" being more desirable.
Old 01-31-2011, 01:20 PM
eatont9999's Avatar
I see, so auto parts stores sell this hose as transmission cooler hose? Good to know.
Old 01-31-2011, 01:27 PM
Correct, it has more braided reinforcement with a thicker wall.
Old 04-13-2014, 01:59 PM
Paige Summers Paige Summers is offline
Paige Summers is starting off with a positive reputation.
transmission lines / cooler
were are the lines located.?
Old 04-13-2014, 02:05 PM
akamacgyver's Avatar
akamacgyver akamacgyver is offline
Clueless spectator!
akamacgyver has a good reputation on FTE.akamacgyver has a good reputation on FTE.
Under the truck from the transmission to the radiator and back on the auto transmissions only.
Old 04-13-2014, 05:23 PM
Transmission lines
Quote:
Thanks ,I have a couple more questions if you don't mind.
Old 04-13-2014, 05:42 PM
Clueless spectator!
Throw them out there someone will help you out.
Old 04-13-2014, 05:44 PM
Transmission lines
Witch side of the Radiator is the Input for the Transmission line.?
Trans cooler install Gg6k 2007 - 2014 Expedition & Navigator 2 01-04-2016 08:53 PM
6.0 Tranny cooler install - quick question Volcom 1999 - 2003 7.3L Power Stroke Diesel 2 08-01-2015 07:24 PM
Transmission coolant line routing. finitetime Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 12-05-2011 07:14 PM
1995 e40d PSD bogie346 1987 - 1996 F150 & Larger F-Series Trucks 2 08-16-2011 08:15 AM
Help with new tranny cooler install RedBoat 1999 - 2003 7.3L Power Stroke Diesel 8 06-08-2010 09:20 AM
Tags
1999, cooler, cooling, correct, diagram, diagrams, f150, f250, ford, hose, installation, line, lines, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
