Transmssion lines and cooler installation - Page 2 - Ford Truck Enthusiasts Forums
Old 04-13-2014, 06:47 PM
akamacgyver's Avatar
akamacgyver akamacgyver is offline
Clueless spectator!
akamacgyver has a good reputation on FTE.akamacgyver has a good reputation on FTE.
It doesn't matter as the transmission provides the flow through the radiator, it will work in either direction. The most common scenario is passengers side in, drivers side out, but again it would work either way.
Old 04-13-2014, 10:14 PM
Paige Summers Paige Summers is offline
Paige Summers is starting off with a positive reputation.
Thanks a bunch
Thanks, after all ive been thru i sure needed something simple to end my night,
Old 03-31-2015, 01:47 AM
Curtis Gruman Curtis Gruman is offline
Curtis Gruman is starting off with a positive reputation.
Quote:
Originally Posted by 87crewdually View Post
The line at the rear of the trans is the return from the cooler.
I run the lines according to manufacturers directions: Coming fron the trans, Front trans line to the radiator cooler, then back out of the radiator cooler to the auxillary cooler, finally out of the aux cooler back to the rear line on the transmission.
see here : Transmission Cooler Diagram Photo 3
Does this diagram work with a 1997 f250 7.3 auto?
Old 03-31-2015, 03:31 AM
87crewdually's Avatar
87crewdually 87crewdually is offline
87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.
Quote:
This is universal and can be applied to any application with an auxilary cooler in addition to a cooler built into the radiator.
Trans cooler install Gg6k 2007 - 2014 Expedition & Navigator 2 01-04-2016 09:53 PM
6.0 Trans Cooler DougJ_1997PSD 1994.5 - 1997 7.3L Power Stroke Diesel 17 09-20-2015 10:47 PM
6.0 Tranny cooler install - quick question Volcom 1999 - 2003 7.3L Power Stroke Diesel 2 08-01-2015 08:24 PM
External trans filter chesster51 1987 - 1996 F150 & Larger F-Series Trucks 1 03-01-2015 06:38 PM
Is this trans cooler doing anything for me? Stinky1 1968-2013 Full Size Vans 7 12-14-2012 12:10 PM
Tags
1999, cooler, cooling, correct, diagram, diagrams, f150, f250, ford, hose, installation, line, lines, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
