wiring diagrams for 2002 ranger edge - Ford Truck Enthusiasts Forums
Old 03-09-2003, 09:56 PM
ColorChangingMan3 ColorChangingMan3 is offline
ColorChangingMan3 is starting off with a positive reputation.
does anyone know the radio wiring diagrams for a 2002 ranger edge, im trying to install subwoofers on an amplifier with an impedance adapter but i need the right wires to splice, can anyone help me.
Old 03-10-2003, 01:53 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Pin Circuit Circuit function
1 19 (LB/RD) Power, Hot with Headlamps on
1000 (RD/BK) Voltage supplied in Start (overload protected) 3
2 57 (BK) Ground
4 not used
5 802 (OG/RD) Speaker, right rear (18808) +
6 803 (BN/PK) Speaker, right rear (18808)
7 805 (WH/LG) Speaker, right front (18808) +
8 811 (DG/OG) Speaker, right front (18808)
797 (LG/VT) Voltage supplied at all times (overload protected) 9
137 (YE/BK) Voltage in Run or Accessory (overload protected) 10
11 694 (BK/LG) audio ground
12 800 (GY/LB) Speaker, left rear (18808) +
13 801 (TN/YE) Speaker, left rear (18808)
14 804 (OG/LG) Speaker, left front (18808) +
15 813 (LB/WH) Speaker, left front (18808)
16 694 (BK/LG) audio ground
1 172 (LB/RD) Radio (18806), output, Subwoofer
4 829 (WH/VT) Remote
3 819 (LG/WH) Radio (18806), output, Speaker, left front (18808)
6 816 (LG/VT) Radio (18806), output, Speaker, right front (18808) +
5 820 (DB/YE) Radio (18806), output, Speaker, left front (18808) +
8 not used
7 815 (LG/OG) Radio (18806), output, Speaker, right front (18808)
2 169 (LG/BK) Radio (18806), output, Subwoofer +
C290c
18A919
1 57 (BK) Ground Shield
Old 03-10-2003, 07:36 AM
AOGDEN's Avatar
AOGDEN AOGDEN is offline
AOGDEN is starting off with a positive reputation.
Send me a fax # by PM and I will fax the diagrams to you. The book is at home and I am at work right now but I should be able to get it to you within a day or 2.
Old 03-10-2003, 11:54 PM
i dont have a fax but if there is any way you can get the diagram on the computer it would greatly help, thank you. This should work anyway.
Old 03-11-2003, 12:31 AM
the adapter only says to tap into right + ,Right -, left +, and left -, do i tap into the front or rear speaker wires, or do i tap the radio output wires
Old 03-11-2003, 07:45 AM
AOGDEN's Avatar
I do have a scanner but I don't know when I will have the time to do anything with it. I work 3 jobs and average 72 hours a week. Free time is usually spent sleeping or hanging with my daughter. When I get the time I will scan it for you.
Old 03-11-2003, 09:17 PM
smokey6309028 smokey6309028 is offline
smokey6309028 is starting off with a positive reputation.
What u can use is available at Radioshack ( no surprise...LOL)
Get a couple of Scotch Connectors. These aloow you to "tap" into a wire without cutting it. You can get the signal from the output wires right at the headunit, OR from the speaker wires. They are the same length of wire going to the head unit.
2002 explorer cigarette lighter electrical wiring diagram dswong01 Explorer, Sport Trac, Mountaineer & Aviator 2 12-27-2006 12:06 AM
radio wiring diagram for a 99 ford ranger F250Wheels Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 07-25-2005 01:13 PM
Wiring diagram needed.............. SarahTee Ranger & B-Series 5 01-10-2005 09:11 PM
wiring diagram BillyBob69 1997 - 2003 F150 2 12-15-2004 09:17 AM
90 Ranger 2.3 wiring diagram droz Electrical Systems/Wiring 1 12-02-2002 05:43 AM
Tags
2002, diagram, digrams, edge, ford, radio, ranger, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
