a well beaten subject-leveling kits and tires/rims
I know this topic has been touched a million and one times, but I thought one more time cant hurt. Maybe I can reach someone who can give me more specific answers. I have a 2008 F350 crew cab short bed. I tow a 5th wheel camper off and on through out the summer. I currently have factory size tires (goodyear dura trac) on 2005 factory lariat rims. I have read a lot on leveling kits, but still have questions. Can/should I install a leveling kit to raise the nose of the truck if towing a couple dozen times a year? And if i did level the truck how do I fiqure out what size tires will fit on the truck and what offset will best work.....or is that best left to a tire shop? if any one is running such a set up, I would love to see pictures.
on my 06 F250 it sat a little to low..only 17" tires and the running boards would scrap off road.
I went to a 4x4 shop which is where you should go...got a 1" add a leaf for the rear and 2 1\2" spacer for the front coils and then a drop down item...can't remember right now for the drag link for the steering.
I also due to the increase got 4 new shocks for it.
It's all up to you...
It really depends on what you want to achieve with your truck. I carry a Lance slide-in camper onto the beach so I wanted some lift (but still watch the center of gravity) and wider tires to help with the beach sand flotation. I have an '08 F250 so the only difference you'll need to worry about is you probably won't need the same rear blocks that I needed. I installed a ReadyLift SST 2.5" Leveling Kit which included front spring spacers and spacer bushings, a cast track bar relocation bracket (to keep the front axle centered), a carrier bearing spacer (if needed) and new OEM style rear blocks (mine were 6" but the F350 takes 5"). I installed 4 - 37X13.5R-17 Toyo Open Country MT tires on 17X8 Helo HE842 wheels with 0mm Offset and 4.5" backspacing with no rubbing - here's two pictures of mine finished:
I hope this helps...
ReadyLift SST then...
Ford F350 Super Duty SST Lift Kit: 2008-2010, 4WD Only - 2.5"F/1.0"R
That's the same kit I have only for the F350 instead of F250 - it works great. I installed it myself and those 37's you see in my pictures fit with just the kit!
Gear should be fine...
I had no problem with mine when I went to 35's - the diesel could care less! However, now that I've gone up to 37's, I have noticed a difference - the Diesel still pushes the truck fine but I bet a gear change would make a difference with the bigger muds. You shouldn't worry though!
Ford F250/F350 SUPER DUTY, 2008-2010, 4WD ONLY - 2.5" w/ track bar bracket
You might be surprised...
this is the one i was looking at, same kit except no rear blocks...i dont want/need to raise the rear of the truck.
I appreciate your help and I know there is only so much one can answer. I guess my next question would be, what is the best way to measure the difference from front to back? Do i measure from ground to wheel opening?
Visual...
I could just tell visually but ground to top center of each wheel opening should be the most accurate method. Mine sat a touch higher in the front because of my "snow plow package" front springs. I just put 8 - 9 lbs in the air bags and it sits perfect - I run 45 - 50 when the camper is on.
Hey Jim, hope you are making through the blizzard. Superduty, I am in the same boat it sounds like, and am watching the thread. I think I am leaning exactly the way you are, although I cant lift until I sell the old truck. This big of a truck sitting this close to the ground is plain wrong.
To both of you, as I think about my truck, with the 37's and that simple 2.5" leveling kit, I really have quite a step up to get in that guy. I can't imagine a 6" or 8" lift kit... the truck sits perfect for me the way it is! I think both of you guys will be happy with that kit
