Low charging volts! - Ford Truck Enthusiasts Forums
Low charging volts!
Old 01-30-2011, 04:23 PM
teppler's Avatar
teppler teppler is offline
teppler is gaining momentum as a positive member of FTE.
Low charging volts!
Back in my days as a Chevrolet mechanic in the 60s the charging voltage was always set from generator at 14.2 volts, while monitoring my voltage on Edge Insight I see it jumping from 13.4 to 13.8 but never over 14. I assume this is normal but seems like 14.2 would do a better job of keeping the batteries charged...comments and discussion welcomed.
Old 01-30-2011, 06:05 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
My DC Power alternator keeps it at 14-14.2 most of the time.
Old 01-30-2011, 06:35 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
13.8-14.2 is ideal. with the lower engine idle we see 13.4 alot, not seen an issue with it
Old 01-31-2011, 12:47 AM
dunenfool dunenfool is offline
dunenfool is starting off with a positive reputation.
With my insight I am only seeing 13.3 tops usually 13.1 at hiway speeds, when it first starts I get down to 10.9 while the glow plugs are on. I just replaced the batteries with 2 brand new ones so I don't think its the batteries. Seems I have a the same symptoms as the original poster. Could our alternators not be able to cope with the electrical loads of our trucks?
Old 01-31-2011, 10:00 AM
hndacr hndacr is offline
hndacr is starting off with a positive reputation.
I just had the same issue. At a stop light, my voltage would drop below 12V. I ended up replacing the alternator. I upgraded to the 140 Amp motorcraft instead of the 110 amp that came on the truck. I am amazed at the things that have stopped working recently... I have 97,000 miles and the truck is an 04.
Old 01-31-2011, 10:23 AM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
For a few minutes after starting, mine runs up around 14.1. Then it drops and hangs anywhere from 13.3 to 13.8 or so.
As long as the batteries are getting charged, I don't think it is a problem.
Alternator voltage fluidp 6.0L Power Stroke Diesel 12 01-31-2016 06:33 PM
battery quetion lead acid vs gel ? chadjones99 6.7L Power Stroke Diesel 41 10-15-2015 07:48 AM
Alternator voltage output NHRA racer 303 1999 to 2016 Super Duty 5 07-08-2015 10:59 AM
Alternator issues? pdqford Electrical Systems/Wiring 17 04-07-2015 04:20 PM
ALT output and batteries KDAVID1 6.0L Power Stroke Diesel 20 02-19-2015 08:04 PM
Tags
06, 131, 2005, 2007, 60, 60l, allowable, altenator, charging, diesel, f250, f350, ford, low, lowest, voltage, volts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
