HEATER HOSE ROUTE - Ford Truck Enthusiasts Forums
HEATER HOSE ROUTE
Old 01-30-2011, 04:16 PM
1974F100 1974F100 is offline
1974F100 is starting off with a positive reputation.
HEATER HOSE ROUTE
1984 300 6cyl w/ a/c...which outlet on the core flows in, and from where on the motor? Top hose from the stat housing flows into the core right? Any 300 pics of the engine bay?
Old 01-30-2011, 04:35 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
This was discussed recently and determined that it doesnt matter wich side of the heater core you use for the in/out.
Old 01-30-2011, 05:22 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
This is also confirmed in the Ford Service Manuals. Routing at the heater core is optional.
Heater Contro Valve Set Up D & D 1967 - 1972 F-100 & Larger F-Series Trucks 2 09-28-2014 06:24 PM
1955 f100 heater Daddyo's garage 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-01-2014 09:23 PM
7.3 IDI Heater Core Flow direction genscripter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 11-14-2012 09:15 AM
94 Explorer Heater Core Question? Jameshuden Explorer, Sport Trac, Mountaineer & Aviator 17 03-10-2006 06:40 PM
Heater core hose routing azwolfman 1987 - 1996 F150 & Larger F-Series Trucks 2 05-23-2005 02:42 AM
Tags
1986, 300, 6cyl, 86, f150, ford, heater, hose, hoses, routing, routung
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
