1979 F150 VIN!! Need Help
Like radar457 said, you'll more than likely need a wire wheel on a drill to be able to read it.
You need to check with the DMV in your state for the final say, but in most states they go by the VIN that is stamped on the frame. If that's the case in your state then make sure the frame VIN matches the title and either reuse the original warranty plate or you can get a reproduction warranty plate from Kevin Marti Marti Auto Works - Concourse Quality, Hobbyist Price
To answer your question though, the warranty plate is on the rear edge of the driver's door, below the latch assy. Most states don't consider this a VIN plate because it can be easily switched out by swapping doors. To be a legal VIN it needs to be attached to a permanent part of the vehicle.
ford4her
56
05-22-2023 07:59 PM
Justin Braun
10-06-2016 10:08 AM
Matt1966
04-26-2016 05:58 PM
badassgixxer100
12-10-2015 09:06 PM
2011coyote
12-31-2010 07:44 AM
