whats the best spark plug for my 6.8
Old 01-30-2011, 11:57 AM
leonilogarcia's Avatar
leonilogarcia
leonilogarcia is offline
can anyone give advice on a spark plug for me????? trying to improve mpg. thanks
leonilogarcia
thanks for the info
Old 01-30-2011, 11:59 AM
jh818's Avatar
jh818
jh818 is offline
I would stick with Motorcraft. Autolites work good as well from what I've read on this forum.
Old 01-30-2011, 05:10 PM
tdappleman's Avatar
tdappleman
tdappleman is offline
The Autolite platinums are almost the same plug as the Motorcraft. Autolite actually makes the Motorcraft plugs. The Autolite numbers are AP103 for platinum and APP103 for double platinum. If you are going through the labor to replace the plugs, make sure you replace the spark plug boots as well and use dielectric grease on the spark plug connection as well as where the boot hits the head. I've seen other plugs like NGK and Bosch not perform as well and typically do not last as long on the 4.6/5.4/6.8 engines.
Old 01-30-2011, 11:36 PM
nyaristo's Avatar
nyaristo
nyaristo is offline
has anyone tried out the E3 spark plugs?
Old 01-31-2011, 07:24 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
Spark plugs are not going to give you any fuel economy gains if the plugs that are in you engine now are functioning properly.
Garbage like the E3, Bosch +4, or others like them that claim such are nothing more than snake oil and will gain you absolutely NOTHING.
JL
Old 01-31-2011, 05:30 PM
59CRL's Avatar
59CRL
59CRL is offline
JL
I agree, all those spark plugs claiming gains are full of BS, snake oil as you say. Most of the big name brands all work well. It is just a matter of preference. I like Motorcraft and Champion.... for the best fuel economy you can get, and it will not be anything great with the 6.8, keep the engine tuned up, clean air filter and tires properly inflated..... cross your fingers and pray you can get 13mpg on the highway. Good luck.
Old 04-01-2011, 12:39 PM
jrings's Avatar
jrings
jrings is offline
Happen to have numbers or a place to get the boots from?
Old 04-01-2011, 12:53 PM
fordboy67's Avatar
fordboy67
fordboy67 is offline
I know Auto Zone has them, I think they are about $4-5 each.
Old 04-01-2011, 01:26 PM
Fosters's Avatar
Fosters
Fosters is offline
Spark plugs are largely all the same with few notable differences... platinum are known not to be great for high performance application as it does not cool down as fast as copper or, the newer iridiums. Copper ones have to be replaced more often, and are thus not that popular. Iridiums are the best of both worlds, the longevivity of platinum - 100k miles - and the cooling of copper (the tip is much smaller on iridium plugs).
The E3, bosch +4, +2, splitfire, etc, are all snakeoil as JL said. Bosch +4 has the added reputation of those ground things breaking off and ruining motors...
I've never had problems with running iridiums in my mach1, and prefer them over platinum, knowing the pre-ignition chance is reduced. I put the same iridiums in the excursion when I changed them, not because I wanted performance, but just don't care much for platinums, and wasn't gonna change them with coppers...
Old 04-03-2011, 10:22 PM
1 Excursion camper's Avatar
1 Excursion camper
1 Excursion camper is offline
Do you want to replace your plugs because your X has recently lost 2mpg?
Old 04-03-2011, 10:41 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Our sponsor Rockauto has 'em too.
Old 04-05-2011, 09:25 PM
Rosson03's Avatar
Rosson03
Rosson03 is offline
Smile I HAVE USED THE E3 SPARK PLUGS ALSO THE FITCH FUEL
reset this was to much
Old 03-01-2012, 05:37 PM
Rosson03's Avatar
Rosson03
Rosson03 is offline
e3 suck! tried them on 2 different vehics
Old 03-01-2012, 05:40 PM
Rosson03's Avatar
Rosson03
Rosson03 is offline
APP103
Has anyone tried
I-Series Iridium Electrode
Tested Benefits:
  • Up to 12% more horsepower and torque
  • More precise and efficient combustion wth fine-wire electrode
  • Better throttle response
  • The last plugs your car will ever need
Performance that you will feel. Guaranteed. (The world's most powerful spark plug from Enerpulse)
Quick Reply: whats the best spark plug for my 6.8
