Can't switch between fuel tks - Ford Truck Enthusiasts Forums
Old 01-30-2011, 12:45 PM
TruckoffFord TruckoffFord is offline
TruckoffFord is starting off with a positive reputation.
I can't switch between my fuel tanks. How does one change out the component (fuel pump) located on the frame uder the cab?
Thanks
Old 01-30-2011, 06:04 PM
eriklane eriklane is offline
eriklane is starting off with a positive reputation.
Fuel switch unit
I just took mine off because I took my rear tank off and suspected the switch unit was causing me issues with flow. But, I dont' understand the reason why there are 2 lines from the tanks. 4 into the switch unit, 2 out-you just unclip the electric cord and then the 4 lines all have a safety clip you have to use a flat screwdriver to pop that out and then the lines come free. Prepare for gas flow, or remove the connection on the top of the gas tank, but some will still be in the lines. I ended up cutting off the plastic ends and using 3/8" fuel line to couple the plastic lines together.
Old 01-30-2011, 06:42 PM
smashclash smashclash is offline
smashclash is starting off with a positive reputation.
there's the extra lines because one line is for feeding the motor and the other is a returns line.
as far as changing out the fuel selector vavle (and assuming yours is equipped with the mechanical one that has the 4 lines pointed toward the rear and 2 toward the front) you'll need to remove (I think 3 10mm) bolts to loosen the valve. Then pull the clips off for each line and the lines slip right off. Wait a while after you shut off the motor before doing this as it will remove more of the fuel pressure. Lastly, be REAL careful when removing the clips and sliding off the fuel lines. The nipples coming off the valve can break pretty easy.
Old 01-30-2011, 07:50 PM
Return gas line
What happens if the fuel pump doesn't have a return line? Can I just plug the tank outlet for that line?
Fuel tank switch Serg Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 02-20-2014 10:17 PM
fuel tank selector 400 .040over 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-01-2012 09:40 PM
After market fuel tank in bed of pickup Patty Jr. Aftermarket Products 0 04-14-2006 12:50 PM
duel fuel tanks ELKMCC 1987 - 1996 F150 & Larger F-Series Trucks 4 06-18-2002 09:17 PM
89 F250 dual fuel tank switch problem JDsnowmobiler Fuel Injection, Carburetion & Fuel System 2 04-03-2002 11:20 AM
Tags
1994, f1, ford, forum, fuel, switch, tanks, tks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
