hydraulic clutch fluid? - Ford Truck Enthusiasts Forums
Old 01-30-2011, 12:43 PM
Tom Norton Tom Norton is offline
Tom Norton is starting off with a positive reputation.
what to use here? some light hydraulic oil or blake fluid or ??
the MG and Triumph (brit) cars used mineral oil IIRC.
Old 01-30-2011, 01:25 PM
84-250 84-250 is offline
84-250 is gaining momentum as a positive member of FTE.84-250 is gaining momentum as a positive member of FTE.
brake fluid. dont know what your driving tho
Old 01-30-2011, 01:27 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
Brake fluid. Mineral oil sounds like trouble waiting to happen.
In fact it might say right on the cap what it takes.
Old 01-30-2011, 01:30 PM
you're right I should have specd for my '86 F250
the brit cars are all I've owned previously that had juice clutch.
thanks all.
Old 01-30-2011, 03:19 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
Just use brake fluid. I have noticed at work now we sell a bottle that looks like brake fluid that says hydraulic clutch fluid. I'm sure someone is making money from relabeling a bottle of brake fluid.
Old 01-30-2011, 03:22 PM
yep, the screw cap does indeed state dot 3 brake fluid - should have taken a peek.
Old 01-30-2011, 05:32 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Oh, trust me, it is on the shelf labeled as hydraulic clutch fluid, and some are adamant about getting it, even though I tell them it is the same thing...
Reccomended Fluid for F600 dump hydraulic cylinder? 1975-F6004x4Dump Large Truck 5 02-07-2014 10:41 PM
Tractor Hydraulic Oil Blurry94 Clutch, Transmission, Differential, Axle & Transfer Case 11 11-22-2013 10:53 PM
Using hydraulic fluid instead? Farmboypowerstroke 1999 - 2003 7.3L Power Stroke Diesel 16 11-11-2011 11:12 PM
Hydraulic fluid mix ? kawa 1994.5 - 1997 7.3L Power Stroke Diesel 11 07-02-2011 07:48 AM
Fluid for Meyers plow? Ford_Six General Automotive Discussion 2 10-27-2009 08:00 AM
Tags
1987, 78, bad, clutch, f100, f150, f250, fluid, ford, hydraulic, hydrolic, inline, location, truck, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
