Modular V10 (6.8l)
PCV Valves on F53 Motorhomes
Old 01-30-2011, 12:25 AM
bonron's Avatar
bonron
bonron is offline
Red face PCV Valves on F53 Motorhomes
MY 2003 Class A motor home has the 310 HP V-10 vin "S". for the las few years I have been having a problems with oil being suck up the PCV line and into the Plenum and it is using/sucking oil and when started after a few days there's a white puff smoke,,clearly it's coming from the PCV as the lines are oil soaked even into ther Plenum I can feel the oil. Has any else had this problem, especially with the ford V-10. Otherwise I really enjoy my motorhome and the V-10 has great power and torgue. I have had no other problem with this unit. Any suggestions?
I getting conflicting info Re: what PCV valve should be on this model,, the owner's manual call for a Motorcraft EV233,,, every where I check the number's are different,,and I believe not all PCV are the same...thanks
Old 01-30-2011, 08:48 AM
efx4's Avatar
efx4
efx4 is offline
This is the 2009-2011 F150 forum, you may want to go down the page to the 6.8 V10 forum. They may be able to help you there.
Old 01-30-2011, 10:45 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Thread moved to the V10 forum.
WELCOME to FTE!
OpenTrackRacer
Modular V10 (6.8l)
03-28-2014 04:36 PM
timbersteel
17
01-13-2012 09:47 AM
bonron
Modular V10 (6.8l)
02-09-2011 01:48 PM
PurerockRacing
Modular V10 (6.8l)
39
03-16-2006 08:53 AM
Jims95Ranger
1983 - 2012 Ranger & B-Series
10-05-2001 11:43 AM
Quick Reply: PCV Valves on F53 Motorhomes
