PCV Valves on F53 Motorhomes - Ford Truck Enthusiasts Forums
Old 01-30-2011, 01:25 AM
bonron bonron is offline
bonron is starting off with a positive reputation.
Red face PCV Valves on F53 Motorhomes
MY 2003 Class A motor home has the 310 HP V-10 vin "S". for the las few years I have been having a problems with oil being suck up the PCV line and into the Plenum and it is using/sucking oil and when started after a few days there's a white puff smoke,,clearly it's coming from the PCV as the lines are oil soaked even into ther Plenum I can feel the oil. Has any else had this problem, especially with the ford V-10. Otherwise I really enjoy my motorhome and the V-10 has great power and torgue. I have had no other problem with this unit. Any suggestions?
I getting conflicting info Re: what PCV valve should be on this model,, the owner's manual call for a Motorcraft EV233,,, every where I check the number's are different,,and I believe not all PCV are the same...thanks
Old 01-30-2011, 09:48 AM
efx4's Avatar
efx4 efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
This is the 2009-2011 F150 forum, you may want to go down the page to the 6.8 V10 forum. They may be able to help you there.
Old 01-30-2011, 11:45 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Thread moved to the V10 forum.
WELCOME to FTE!
Oil residue in intact tract from PCV OpenTrackRacer Modular V10 (6.8l) 1 03-28-2014 05:36 PM
PCV valve sticks open after starting... timbersteel 1987 - 1996 F150 & Larger F-Series Trucks 17 01-13-2012 10:47 AM
PCV Problem bonron Modular V10 (6.8l) 14 02-09-2011 02:48 PM
PCV valve sucking oil PurerockRacing Modular V10 (6.8l) 39 03-16-2006 09:53 AM
PCV Valve Rattle during acceleration Jims95Ranger Ranger & B-Series 1 10-05-2001 12:43 PM
Tags
f53, ford, located, pcv, v10, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
