Air to fuel ratio question.
Its not that easy 1 gallon of fuel wieghs about 6 lbs and air wieghs about .010026lbs per gallon and say you get 10 miles per gallon that says you use 648 gallons of air for 1 gallon of gas. A 351 and 1800rpm doing a mile a minute would use .1gallons of fuel while using 2844 gallons of air. Somethings not right.
Air = .075#/cubic ft
Gas = 6#/gal
Gas = 6#/gal
We are dealing with molecular MASS the fuel and air. Here is a quick example.
The stoichiometric air-fuel ratio is the ratio at which all oxygen is used up and all fuel is completely burnt. This ratio is a basic property of a fuel and is the result of its chemical composition. Let’s for example look at natural gas (methane). When burning any carbon-based fuel, carbon dioxide and hydrogen are formed. Going back to the methane example, the following reaction equation describes the oxidation of the fuel:
CH4 + 2O2 -> CO2 + 2H20
Following from the equation, we need 2 molecules of oxygen for every octane molecule.
If we look up the atomic weights of the atoms that make up octane and oxygen, we get the following numbers:
Carbon (C): 12,01
Oxygen (O): 16
Hydrogen (H): 1,008
So 1 molecule of methane has a molecular weight of: 1 * 12,01 + 4 * 1,008 = 16,042
One oxygen molecule weighs: 2 * 16 = 32.
The oxygen-fuel mass ratio is then: 2 * 32 / 1 * 16,042 = 64 / 16,042 = .
So we need 3,99 kg of oxygen for every 1 kg of fuel.
Since 23,2 mass-percent of air is actually oxygen, we need : 3,99 * 100/23,2 = 17,2 kg air for every 1 kg of methane.
So the stoichiometric air-fuel ratio of methane is 17.2.
Common fuels
When the composition of a fuel is known, this method can be used to derive the stoichiometric air-fuel ratio. For the most common fuels, this, however, is not necessary because the ratios are known:
Gasoline: 14.7
Natural gas: 17.2
Propane: 15.5
Ethanol: 9
Methanol: 6.4
Hydrogen: 34
Diesel: 14,6
Carbon (C): 12,01
Oxygen (O): 16
Hydrogen (H): 1,008
Common fuels
Gasoline: 14.7
Natural gas: 17.2
Propane: 15.5
Ethanol: 9
Methanol: 6.4
Hydrogen: 34
Diesel: 14,6
traildogg
1999 to 2016 Super Duty
17
10-20-2015 10:13 AM
pongolo
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
06-03-2010 11:14 AM
workingdog
21
10-26-2006 09:54 PM
